Quentin Jarrell
Lower power sub for 2014 ???
I'm waiting on pricing on the current iteration of a 1,000 watt line with 20mm xmax.  The parameters on the sub will be very similar to the Ethos and will use the same exact high quality softparts.  Mounting on the 12 inch version will be 5 7/8 inches and due to the motor venting machined at 45 degree angles in the backplate no spacing will be required between the backplate and enclosure for ventilation.  As long as pricing is right the below iteration will be available around August.
Almost forgot,  OD is 220mm, so it'll allow for a 10" version.
Sounds promising. Hopefully it will turn out as well as the ethos did
Sounds like. Good plan. Nice to see things working out for you Quentin!
