Recently Browsing 0 members
Recent Topics
- 3 comments
- 64 views
- 398 comments
- 33,192 views
- 18 comments
- 302 views
- 4 comments
- 138 views
- 2 comments
- 724 views
- 5 comments
- 1,567 views
Similar Content
By antoinez28
I have for sale two crescendo bc 2000 for sale both are about 1 1/2 years old good deal power by two g31 batt juciebox, and crescendo logic...pushing 2 18" ethos strapped at 2ohm never seen below 12volt...I had to push them....got warm in this hot Kansas City weather...both will come with bass noobs and one with owners books the other might be lost during a move with both boxes from crescendo...I love these things they both went to db-r for repair but nothing major I had a bad ground and thought I blew them both
Crescendo BC2000D
Stable down to .5ohm on strong electrical.
Up to 16.8v capable on BC2000
Remote Bass/Gain knob with Clipping Indicator.
Custom tooled, proprietary Multi-piece Thermal optimized Heatsink with patent pending interlocking slide-out CNC engraved top plate.
2 stage copper anodized removable top plate.
Silver plated high end hard-wired Tiffany RCA inputs and oversized 1/0 Power/Ground Inputs for efficient current transfer.
Overbuilt Power supply with heavy copper traces and Military spec PCB/heavy duty standoffs for extreme vibration resistance.
Manufactured using some of the highest quality and most reliable electrical components, with many 3% tolerance components throughout.
Full 4-Stage Intelligent protection Circuitry 1 Year/1ohm comprehensive warranty with 2 year/.5ohm optional extended warranty available.
Rated Power Output(RMS)
Clean RMS power on 13.8v standard electrical system:
Ohm Load
BC2000d
1ohm
2250
2ohm
1100
4ohm
700
Dimensions: BC2000: 16"L x 2.75"H x 9.5"W (at widest point)
I want 550.00 for the pair or 300.00 each shipped no lower
I'm upgrading to a bigger amp dd-m4a
By antoinez28
So I'm been on the web looking at different types of 5k amps that are linkable amps, so I can upgrade my current amp set up...I'm looking for a amp out of these new or used- dd m4a, sundown audio 4500, crescendo bc5500, dc audio 5k, ampere audio 5000.1. It has to be able to do around 3800-4000 wire down to 1.3ohms.
Running 3-18s DSS ethos box is in the works....
Electrical is dual alts stock will run the truck, mid, and highs the singer 270amp will run only for the battery bank. 4 juice box blackcherry battery back, two runs of 1/0 wielding wire.
( would like more batts if space would allow)
( playing music daily and burbs on comps)
I'm not looking for a father and son conversation here just wanting to know which amp would be better suited for my set up that's all thanks for reading.
By AudioFiLe
in my last decision problems thread i narrowed down which subs i wanted to get. ultimately, everyone steered me in the DSS direction so i ended with 2 12" DSS Ethos subs in a ported enclosure. now since i dont have many of the tools needed to make a proper sub enclosure atm, i will be buying one. i have 2 specific ones i found on ebay that i think might do the trick. they are:
http://www.ebay.com/itm/DUAL-12-Inch-CUSTOM-PORTED-CAR-AUDIO-SUB-WOOFER-ENCLOSURE-4-CU-FT-TUNED-32Hz-/400326247663?pt=US_Speaker_Sub_Enclosures&hash=item5d354dc4ef
OR
http://www.ebay.com/itm/DUAL-12-Inch-CUSTOM-PORTED-CAR-AUDIO-SUB-WOOFER-ENCLOSURE-5-CU-FT-TUNED-34Hz-/400326264513?pt=US_Speaker_Sub_Enclosures&hash=item5d354e06c1
was hoping you pros could direct me to the one that these ethos would sound the best in while still being loud.
also if there are any better choices than these ones that are under $250, would love to hear about em. thanks!
Recent YouTube Posts
