Anyone own seen or heard the new subs from soundqubed? Looking into possibly running one of the 12" version
hmmm.....
I cant find any info on the enclosure's they need......... Kind of pisses me off.
I've never personally like the sound of the aq/sq subs very hollow.and yes I've heard them in proper enclosures.
I had the 15. Was good but definitely better choices IMO.
I heard an HD3 15 trunk walled in a lancer, and for a fifteen in 4.5 @ 33hz, on 1500w it rolled off high as hell, the low lows just weren't there. The higher notes were forceful, but the lowest notes just went missing.
We need to let you sit in our demo vehicle!
I have personally liked the sound of the aq/sq subs cuz they slam and play LOUD, in the proper enclosure.
Edited by AMI CUSTOMS
X2.....  SQ subs are some of the best on the market.   I think some of these guys don't know who the Black Nasty is.
We get it bro, you like Soundqubed, maybe later you can post something substantial, like an intro in the new members section, instead of peanut-buttering Sq's balls. And that's no slam to Soundqubed, I have no opinion on something I have no experience with. I just don't like minions that only run around posting nut-hugging. Reminds me of Kevin and his little posse. *shudders
Edited by gprestonmoto
Well I am sorry but I am not ready for that kind of relationship yet. But thanks for the consideration!!!
I support a company that supports me. Pretty simple logic.
Guest Denzel garner
Ok besides all the bs what would sound better in a trunk setup 2 hds300 15" are 1 hdc3 15" are a single ab xfl 15" are maybe a pair
Guest Denzel garner
Either way it go i only have 2 5.1 cubic ft boxes a single 15" an a dual 15" box im tryna choose wich is better with the space i have
Guest Denzel garner
Thanks ami custom so what your sayin is 2 hds300 15" in the dual 15" 5.1 cubic ft box would be better right???
What's the amount of space in the box and how much port area? Also tuned to what? Is it 5.1 cubes total for both 15s or 5.1 per?
It depends on power, but all things equal 2 15s will give greater output.
Guest Denzel garner
Thank you bassink for your reply for taking so long i was at work but the box is 5.1 cubic ft an have seperate chambers im not sure the size its a custom build tuned to 33hz...but i also seen a box on soundqubed for 2 15" should i just go with that box over the custom box???? An amicustom i well be powering the hds3's with a q1-2200 ..
Guest Denzel garner
i meant sorry for me taking so long to reply i was at work an really appreciate u guys help on this this would be my first very powerfull system an just need sum advice om wich route to take thanks to whoever take the time to reply..
If you're serious about this, build a custom box. Before buying anything you need to measure the space you have and then pick subs out. Post you're max dimensions and we can help you figure out what size and how many subs you should go with.
And start a new thread so were not blowing this one up.
Guest Denzel garner
dimension on of the boxes is 120.92 x 60.96 x 45.72 and my other box is the single 15" ported box from soundqubed the atrend box
Guest Denzel garner
An ok i will make a new thread now
Man i had a 18" AQ HDC3 a few years back. Banged hard on mid and high bass but died off on the lows. My buddy just picked up 3 12" HDS300 and put them in his Ram inverted port up (dont know the exact dimentions of the box but i think it was tuned around 33hz) moves crazy air and sounds great for fairly cheap subs.
Completely different suspension between the two, that is why they sound so different, amount other things....like the coil and motor size.
    1. Recent Topics
        • 3 comments
        • 68 views
        • 398 comments
        • 33,235 views
        • 18 comments
        • 308 views
        • 4 comments
        • 142 views
        • 2 comments
        • 728 views
        • 5 comments
        • 1,571 views
  • Similar Content
    • By Ryann627
      Thanks in advance guys.
    • By Aaron Clinton
      A brief introduction to the all new SSA Demon, but first a farewell to its predecessor.
           Our very long running SSA Dcon has ridden off into the sunset, or at least taking a breather.  The SSA Dcon was our second subwoofer model we ever launched.  At the very beginning, we had the Icon and as it gained traction we saw there was a need for a pure SQ sub of more modest power rating than that the Icon.  So in early 2008, the first SSA Dcon was launched.  (The Xcon followed shortly after).  That being said, the Dcon was almost an immediate hit, with a long 2" copper coil (rarity to have one made in the USA) triple stack motor, rear vent.  The Dcon was very affordable, well made, quite efficient, clean across the entire range, and flexible with enclosure demands.  It is interesting as there are some SSA Family members who swear by their Dcon and will not give it up ever.  (It even became a favorite of some of the home audio crowd).  All that being said, the Dcon evolved a bit for its second generation, we made a leap forward in motor force moving to what is best described as a scaled down Xcon motor, with a large single slug, solid pole, and deeply bumped back plate, while beefing up the suspension and leads.  We were able to bring the power handling up 33% while not hurting the sound that made the Dcon successful.  There was a stretch of a few years, before we ran out of stock, that the SSA Dcon 12 was our all time best selling subwoofer.  So its existence was very important to SSA.  Well with changes in the market (read:customer demands and amps getting much cheaper), as well as sky rocketing material costs, building the Dcon in the USA no longer was an option, so production stopped early 2017 for both the Dcon (and Gcon) and inventory ran out later that year.
           Late last year, due to the long lay off with out the Dcon (and Gcon), we started development of an updated Dcon at a new build house.  The quality and performance of our SSA Evil1 tweeters were above our expectations, so we decided to send more production to that same build house.   As we saw that the market slowed overall for modest power rated subs due to power getting cheaper and people wanting higher power handling subs, so the market began to really start heating up in the 500 - 1200 watt range, I knew we needed to address it.  There is an 8" model developed, but it will not make it this first production run.
           The new model had to handle more power and have more xmax while not sacrificing the balanced and clean sound the Dcon had established for nearly a decade.  That meant larger motor, larger coil, more suspension, larger leads, thicker cone, taller surround, etc.  In the end, all of the changes that happened to the over all design, we could no longer call it a Dcon.  In sticking with the theme of the Evil, a model name that has become so well known, while respecting the Dcon, the Demon name was selected.  The Demon is a great blend of the previous Dcon and Xcon, both in design and appearance.  In prototype testing, the SSA Demon thrived smaller to mid-sized ported and mid-sized sealed enclosures.
      Quick SSA Demon stats:
      2.5" copper coil Aluminum former Aluminum Shorting ring Solid pole, non-vented bumped back plate Large single slug motor Pressed pulp cone Tall roll surround Push terminals Dual Nomex progressive spiders Stitched tinsel leads Large dome dustcap I will list T/S specs and enclosure recommendations shortly.  We are very excited about the SSA Demon as it bringing back to our line up a pure sound quality subwoofer that will be affordable, while still having the characteristic SSA warmth and output.
    • By Ksweds
      Hi, does anyone know the diameter on a soundqubed hdc3.110? Manufacturer doesn't list this, and I can't find it anywhere. I've got an odd shaped box I want to throw a pair in, but I need to make sure they'll fit first
    • By DedicatedEnthusiast
      B2 Audio X2C 15
      $650 shipped!
      Contact at 440-915-2309 for further questions/concerns.
  • Recent YouTube Posts
