whitey
new frequency and power issues, need some feedback/suggestions
i just got a new box built for my subs ( 2 12 inch dual 2 ohm L5 kickers in a 6.5-7 cube box tuned to 35 htz). i picked it up from the guy and set my amp at 25 htz with the gain set at about half way from what i can see on the dial. first, i must say it sounded amazing! i was running a 3.3 cube box that was kinda jimmy rigged together by the guy i bought them from so this is exquisite great sound, good range and a ton of sound pressure. if anyone needs a box built in central to eastern washington/ central idaho let me know i'll get you in contact with triticum audio.
ok, so the guy that built my box also installed the subs and wired in at a 4 ohm load. about a week after i got them home i got curious and pulled the subs out and switched everything to a 2 ohm load. it sounded awesome. great lows, tons of pressure and great sound quality. next time i had it going and my amp kept shutting off at mid to high volume and it sounded like i had a couple of crap tens in cardboard boxes. never had this issue. i'm running a kenwood amp rated at 500rms@ 4 ohm, 900rms@ 2ohm and they were even advertised to be 1 ohm stable. i have 1/0 power cable and 2/0 ground with solid copper terminals on both ends cause i filed down a set of terminals to actually bolt into my amp. i replaced my body ground with a piece of 1/0 instead of the 4 gauge i have for my big 3. changed the subs back to 4 ohms. i'm still not picking up the really low frequencies i was getting. tuned it in, and it sounded decent. tried running at 1 ohm and blew out 2 fuses simultaneously. back to 4 ohms.
                                              NO CLUE WHATS HAPPENING!!!!!
is my amp taking a crap? could it be my off the shelf kenwood deck? could it just be my subs? do you have to acoustically reference each sub according to which voicecoil produces what?
                                                           NO CLUE!!!!!
Two D2 ohm subwoofers can only be wired into 8, 2, or half ohm. I bet you switched from 2 ohm to half ohm. Your amplifier will hate that.
It would help to know how you have your subwoofers wired together and how exactly did you set your gain.
You ran it down to half an ohm not 2
well my gain is actually labeled as input sensitivity. i had it at about 2 volts, now its set at around .75 for the sake of volume. when i said 4 ohm, i had the coils in parallel subs together in series. i reversed this putting the  coils in series subs in parallel.
So you did go from 2 ohms to half ohm which your amplifier will not be able to handle. Also you can not use your input sensitivity knob as a volume knob. The level needs to be correctly set to match the output of the headunit.
Maybe I'm reading it wrong, but it looks like he stayed with a 2 ohm load, just turned the gain up? D2 coils in series make 4 ohm, those wired in parallel make 2 ohm, correct?
series/parallel is 2 ohm final load
parallel/parallel is half ohm final
and you can only wire series/parallel. Parallel/series is not an option, so I believe he is referring to parallel/parallel
He didn't do parallel/parallel, his second config said he was coils in series subs paralleled.
This is why it would help to know exactly how he did wire them. Rereading maybe he just reversed the polarity?
I would definitely bet on accidentally ending up with half ohm, and I'm also fairly certain Kenwood amplifiers are normally rated to 2ohms and not necessarily even one ohm stable, let alone .5
ok i didn't know that. i'm just getting into most of the technical parts of car audio. so i just checked and the manual says the "preout level" is 2500mv @ 10k ohms is that what i'm looking for? match that on the amp?
alright i will re explain the wiring to my understanding:
configuration 1) i had each subwoofer's coils, wired together in parallel, red to red, black to black. each sub had a pos/neg lead on one voice coil, and i used another 2 wires to jump across to the other coil. each main pos/neg lead goes from the sub, to a terminal on the back of the box.from the amp at the terminal i have the neg wire hooked to one terminal, and the pos hooked to the other terminal with a jump wire going in between.
configuration 2) i had each sub's coils wired with the pos lead to the poa of coil A, and the neg to coil B and a jumper between the remaining push terminals.each sub has it's own terminal in the box. outside the box, each terminal had it's own wires providing power; no jumper wires going between since my amp has 2 pos and 2 neg terminals. ( not a 2 channel )
configuration 3) voice coils in parallel, terminals outside in parallel.
i thought configuration 1 was a 4 ohm load, configuration 2 was a 2 ohm load and configuration 3 was a 1 ohm load.
Edited by whitey
POS lead.  I can't read that anyway but piece of shit.
Perhaps keep this simple.  Use +/- or red/black  add a A or B depending on which sub.  Would be a bit easier to follow.
    1. Recent Topics
        • 17 comments
        • 178 views
        • 393 comments
        • 32,175 views
        • 2 comments
        • 670 views
        • 5 comments
        • 1,446 views
        • 6 comments
        • 1,015 views
        • 1 comment
        • 961 views
  • Similar Content
    • By Second Skin
      The awesome guys at Colorado Car Audio just finished a sweet Dodge Ram 3500 Pro Master Van build with full sound and heat insulation along with a stereo upgrade and the work is very nice!!!
      They applied Spectrum and Damplifier Pro CLD to all of the metal to kill vibration noise and help with heat transfer through the metal. They used Luxury Liner Pro MLV+CCF next to block out unwanted airborne noise and thermally insulate the walls. And they used Mega Zorbe Hydrophobic Melamine Foam to absorb sound and thermally insulate the roof of this huge van!!!
      When the proper layers are applied to the correct locations, a huge difference in noise level reduction can be achieved. Setting the stage for a nice and clean platform for your stereo to perform in a much more enjoyable environment....especially with these tin can sprinter vans....treating them makes a HUGE difference in noise comfort levels.
      Thank you guys for the awesome work and pictures. Thank you for insisting on high-quality Second Skin products for all of your builds. #TeamSecondSkin #SecondSkinUSA #SecondSkinAudio #SecondSkinForTheWin
      Spectrum Liquid Sound Deadening
      Luxury Liner Pro Mass Loaded Vinyl with Closed Cell Foam infused
      Mega Zorbe Standard Hydrophbic Melamine Foam
      Damplifier Pro
      New Kenwood Touch Screen Head Unit
      Upgraded Stereo System
    • By SoundQubed
      Check out this super sweet awesome deal we are having for tax season!!
      www.soundqubed.com
    • By afearlesshunter
      Hello all! This will be really really slow going since this is a high school build lol. Anyways, I started out 2 years ago with a 92 pontiac sunbird and put a little pioneer 12 in it and its been a steady road ever since. Here i am now with a newer vehicle and bigger plans.
      Vehicle: 03 Jeep Grand Cherokee
      Current Gear:
      Kenwood KDC-X397
      4 gauge knu cca
      Alpine MRV-500
      SSA Xcon 18
      Future:
      Crescendo Symphony 1500 (hopefully soon)
      1/0 Welding Cable
      ....maybe two xcons c-pillar wall....
      The jeep
      Kenwood
      Most recently removed setup
      Box
      And its In!!!!
    • By rmksledhead
      Figured I should start a build log since I've gone through so much trial and error in getting this stereo to sound good.
      I'm already done with most things but I did take pictures along the way so i'll get that all uploaded when i get photobucket or imgur figured out.
      I bought my passat almost a year ago, the weekend after black Friday to be exact, and knew immediately that it needed some love in the bass department.
      I had a rockford p-300-12 powered enclosure lying around that i once had mounted in a big self-propelled sprayer that i basically lived in for 3 summers, threw that in along with a rockford loc, rockford rca's, and some ebay 4ga cca to get it powered.
      That sounded awesome for the average non-basshead and would suffice until i found a real solution....
      Did some searching and found this great place! After searching and reading here for hours I decided on a Fi BL 12 for a sub and a BRZ1200.1 hifonics amp to power it since i'm a poor college student and can't afford a bc, aq or saz lol
      I built a vented box for the BL that was 2.68ft^3 tuned to 28.5hz
      After I finished the box I had to stuff foam above the headliner near the upper brake light and under the rear deck to stop some rattling. Installed some dampener (dynamat and ebay stuff) to the trunk lid, under the trunk carpet on the floor, and rear deck from inside the trunk. dampener helped a ton.
      After the substage I realized that the stock front stage was not going to cut it... I knew that I wanted to fill some of the lacking upper bass frequencies with some volume so I was looking for the biggest components I could get for a decent price. Ended up getting the xr1800p components from Kenwood. They've got a big 7" woofer and an oversized 1 3/16" tweeter with external crossovers. currently the set is being powered by a dusty old pioneer 4-channel amp GM-x524. I'm not perfectly satisfied with the front stage for now since the amp likes to protect at high volumes and I've got some fuzzy distortion from the tweeters in certain frequencies. once i change the amp to the GM-d8604 class d 4-channel from pioneer I think it will get much better as I have the older GM-d9500f version in my s10 that never protects and has no distortion until extreme volume.
      also ran another 4ga run of cca to the trunk and a distribution block when I added the second amp.
      Also changed out the stock HU for a Pioneer Avh2600bt touchscreen unit which is fantastic for the money.
      I decided that the box was tuned too low so I chopped 10.5" off the port giving me a 2.88ft^3 net volume tuned to 32.2hz and was much happier!
      Now for the real reason I'm starting this build log.. I'm going to try a 6th order bandpass to keep this 'new to me' low end rumble and get back the awesome upper frequency volume from my mtx square sub in my s10 for when i want to blast the 50hz Flux Pavilion bass cannon!
      Much more to follow, including pics for the above^ stuff!
  • Recent YouTube Posts
