new frequency and power issues, need some feedback/suggestions
By
whitey, in Amplifiers / Head Units / Processors / Electrical
Recently Browsing 0 members
Recent Topics
- 2 comments
- 52 views
- 398 comments
- 33,056 views
- 18 comments
- 291 views
- 4 comments
- 119 views
- 2 comments
- 719 views
- 5 comments
- 1,555 views
Similar Content
By Second Skin
The awesome guys at Colorado Car Audio just finished a sweet Dodge Ram 3500 Pro Master Van build with full sound and heat insulation along with a stereo upgrade and the work is very nice!!!
They applied Spectrum and Damplifier Pro CLD to all of the metal to kill vibration noise and help with heat transfer through the metal. They used Luxury Liner Pro MLV+CCF next to block out unwanted airborne noise and thermally insulate the walls. And they used Mega Zorbe Hydrophobic Melamine Foam to absorb sound and thermally insulate the roof of this huge van!!!
When the proper layers are applied to the correct locations, a huge difference in noise level reduction can be achieved. Setting the stage for a nice and clean platform for your stereo to perform in a much more enjoyable environment....especially with these tin can sprinter vans....treating them makes a HUGE difference in noise comfort levels.
Thank you guys for the awesome work and pictures. Thank you for insisting on high-quality Second Skin products for all of your builds. #TeamSecondSkin #SecondSkinUSA #SecondSkinAudio #SecondSkinForTheWin
Spectrum Liquid Sound Deadening
Luxury Liner Pro Mass Loaded Vinyl with Closed Cell Foam infused
Mega Zorbe Standard Hydrophbic Melamine Foam
Damplifier Pro
New Kenwood Touch Screen Head Unit
Upgraded Stereo System
By SoundQubed
Check out this super sweet awesome deal we are having for tax season!!
www.soundqubed.com
By afearlesshunter
Hello all! This will be really really slow going since this is a high school build lol. Anyways, I started out 2 years ago with a 92 pontiac sunbird and put a little pioneer 12 in it and its been a steady road ever since. Here i am now with a newer vehicle and bigger plans.
Vehicle: 03 Jeep Grand Cherokee
Current Gear:
Kenwood KDC-X397
4 gauge knu cca
Alpine MRV-500
SSA Xcon 18
Future:
Crescendo Symphony 1500 (hopefully soon)
1/0 Welding Cable
....maybe two xcons c-pillar wall....
The jeep
Kenwood
Most recently removed setup
Box
And its In!!!!
By rmksledhead
Figured I should start a build log since I've gone through so much trial and error in getting this stereo to sound good.
I'm already done with most things but I did take pictures along the way so i'll get that all uploaded when i get photobucket or imgur figured out.
I bought my passat almost a year ago, the weekend after black Friday to be exact, and knew immediately that it needed some love in the bass department.
I had a rockford p-300-12 powered enclosure lying around that i once had mounted in a big self-propelled sprayer that i basically lived in for 3 summers, threw that in along with a rockford loc, rockford rca's, and some ebay 4ga cca to get it powered.
That sounded awesome for the average non-basshead and would suffice until i found a real solution....
Did some searching and found this great place! After searching and reading here for hours I decided on a Fi BL 12 for a sub and a BRZ1200.1 hifonics amp to power it since i'm a poor college student and can't afford a bc, aq or saz lol
I built a vented box for the BL that was 2.68ft^3 tuned to 28.5hz
After I finished the box I had to stuff foam above the headliner near the upper brake light and under the rear deck to stop some rattling. Installed some dampener (dynamat and ebay stuff) to the trunk lid, under the trunk carpet on the floor, and rear deck from inside the trunk. dampener helped a ton.
After the substage I realized that the stock front stage was not going to cut it... I knew that I wanted to fill some of the lacking upper bass frequencies with some volume so I was looking for the biggest components I could get for a decent price. Ended up getting the xr1800p components from Kenwood. They've got a big 7" woofer and an oversized 1 3/16" tweeter with external crossovers. currently the set is being powered by a dusty old pioneer 4-channel amp GM-x524. I'm not perfectly satisfied with the front stage for now since the amp likes to protect at high volumes and I've got some fuzzy distortion from the tweeters in certain frequencies. once i change the amp to the GM-d8604 class d 4-channel from pioneer I think it will get much better as I have the older GM-d9500f version in my s10 that never protects and has no distortion until extreme volume.
also ran another 4ga run of cca to the trunk and a distribution block when I added the second amp.
Also changed out the stock HU for a Pioneer Avh2600bt touchscreen unit which is fantastic for the money.
I decided that the box was tuned too low so I chopped 10.5" off the port giving me a 2.88ft^3 net volume tuned to 32.2hz and was much happier!
Now for the real reason I'm starting this build log.. I'm going to try a 6th order bandpass to keep this 'new to me' low end rumble and get back the awesome upper frequency volume from my mtx square sub in my s10 for when i want to blast the 50hz Flux Pavilion bass cannon!
Much more to follow, including pics for the above^ stuff!
Recent YouTube Posts
