forsellb
Mayhem 12 recone/rebuild
Sorry to ask because I know it's all over the forum but I cannot figure out what I need or where to get it. My AA has broken tinsel leads on one voice coil and I have no clue how to fix it. I would assume to fix it the right way, I'd need to pull the cone out, but after that I'm not sure what parts I'd need to repair it.
Picture? I resoldered the lead on my evil back to the coil lead.
I just put it back together, but it's about 1/4 away from the coil inside the spider. I may be using my terminology wrong, but that's the best description I can give.
hopefully you understand what's caused the lead to tear? over excursion.
check your setting, enclosure, and install. make sure the SSF is set correctly.
Really? I wonder how I managed that. I haven't been pushing too much power, the box is actually 2cu ft tuned to 40hz, and all my setting are fine. How would that have happened?
