Quentin Jarrell
SPIDER JIG
I've received several emails and PM's on how I create my spider packs.  I needed to make some more jigs to keep up with production so I figured I'll show how I do it.
The spiders I use do NOT lay flat they must be pressed.  This is how they look stacked.
This is the bottom portion of the jig.  It has cut outs for the spider to lay into along with cut outs for the leads.
I put a bead of glue around the outside and the inside diameter of the spider.  It doesn't take much just a small bead.  Then they are stacked on top of each other.  In this case 4. Note that NO accelerator is used ONLY CA glue.
Then the top goes on and is tightened down with the bolt and nut.  The bolt on this jig is long enough for two jigs at the same time.
After 5 minutes, yes 5 minutes it is taken apart and your left with a sandwiched spider pack.
Cool, thanks for sharing Q
Looks good Q
Ahh yes. We used duct tape on the mdf so the glue would stick to the jig.
