Followers
0
Recently Browsing 0 members
Recent Topics
- 397 comments
- 32,980 views
- 1 comment
- 47 views
- 4 comments
- 112 views
- 17 comments
- 282 views
- 2 comments
- 717 views
- 5 comments
- 1,550 views
Similar Content
By Joshdashef
Hello and welcome to my daily headaches! I'll start this build log off with my past setup, my current, and finally update throughout December as I work on probably the furthest this little Civic will let me go.
My instagram: https://www.instagram.com/joshdashef1/
The Past Build:
Head unit: Pioneer 80 PRS
Mono Amp: Rockford Fosgate Prime 750.1
Subwoofers: Rockford Fosgate P3D4 12" (two)
Kicker 4 gauge amp kit OFC
Stock Electrical (alternator included)
Did do the big three sometime between here and current build
Prefab Box: Q-Power Box (Dual 12s)
Tips: Tesa taping RCA's, Marking RCA's Low/Mid/High or similar,
Big Three with loom. Wire was Sky High 1/0 OFC with some 1/2" loom I believe. Old military style terminals (DO NOT USE THESE) they cracked my battery eventually.
By mklett33
Hello and welcome to my version of the “How to Build a Custom Subwoofer box Tutorial”. This tutorial aims to teach you not only how to create a subwoofer box but how to add additional styling and design to make it a one of kind masterpiece.
This is a four part tutorial series; a brief description of each part is given below and accompanied with a video and pictures. Enjoy!
Part 1: How to Build the Box
In this first video I cover the basics of a box design, incorporating bracing and 45’s and construction techniques.
Part 2: Customizing the Box
This video covers the design and production of custom template created insert shapes that mount to the front of the box and can be used to accent and tie to other parts of the install. These techniques can be used on other aspects of your install like custom door panels, and more.
Part 3: Molding the metal mesh
Molding metal grill mesh gives a very custom look to our box, you could use this technique to hide a port, or protect the speaker itself.
Part 4: Wrapping with Vinyl and Carpet
In this final video we finish the custom box by wrapping it with carpet and the template shapes with vinyl.
Thanks for watching and learning! Now that you have learned these new techniques what would you use them on?
By DedicatedEnthusiast
Crescendo BC3500D is approximately six months old, has never been exposed to low voltage and has no scratches, dings or dents whatsoever. Does 3,875 watts RMS at 13.8v
Xs power XP3000 battery is sitting at over 12.7v after being out of my car for several weeks now and is rated to support 3,000 watts rms power
2/0 welding wire is rated to support over 400 continuous amps of current and has already been heat-shrinked and fused for both positive and negative runs from front to back plus the big three upgrade and an additional trunk ground if you so wish to use it
WIRE CAN BE HAD FOR $120 SHIPPED FORGOT TO PUT PRICE AMONG OTHER INFO ON SALES SHEET
Recent YouTube Posts
