Wonder about my alts
By
antoinez28, in Amplifiers / Head Units / Processors / Electrical
Recently Browsing 0 members
Recent Topics
- 2 comments
- 52 views
- 398 comments
- 33,056 views
- 18 comments
- 291 views
- 4 comments
- 119 views
- 2 comments
- 719 views
- 5 comments
- 1,555 views
Similar Content
By mikebingham34
Hello all, I have been away from the forums for some time since graduating college and started working again. Now that I have some money to finally move away from these seemingly low powered setups (6 systems since 2012), I am looking for help with my wall build. I am going to be building the base to the wall in my 2016 Ford Focus sedan in a week or two, and there is a lot of room to work with (over 30 cubes). I will be running 2 18" ZCONs on (undecided) either a 5.5k or 6.5k amp with supporting electrical (batt bank, lots of OFC wire, and HO alt). This is my daily, and I just want a ground pounder with no care to what numbers it'll put up in the lanes. I would like to demo a lot. I'm thinking 8 cubes per sub (16 cubes net) tuned to 32 Hz is a good place to start (recommended by SSA). I'm thinking either a center slot port, or a top port.
** I listen to ALL kinds of music, Decaf/DJSNT, rap, hip hop, metal, rock, 80s/90s pop, jazz, country, movie scores, blues, dubstep/electronic, classic rock, oldies, etc, etc..**
Now... my questions are: How much port area do y'all recommend? Is 8 cubes of net volume per sub a good amount? Should I be alright running an underrated 5500 watt amp, or go with the 6500? What port orientation shall I go with?
If I think of more questions, I will be sure to post them.
P.S. Sorry if I am asking some questions that are common knowledge among these builds, but this is my first "loud" and "high powered" setup. My two loudest systems thus far have been a single Obsidian Audio 15 on about 900 watts, and 2 Sundown Ev3-12's on 1300 watts.
Thank you for your time and patients everyone! Cheers.
By Jon
I recently purchased a SSA Evil 18in sub, and a 3k rms amp. my first ever real set up so im pretty new to car audio. but i have a question and in need of advice. when i turn up the volume it almost sounds like the subwoofer is bottoming out or making a clicking noise. is this normal or do i need to lower the power on it. or is there more to it than just that?
By spanky1975
I am trying to run the auto-eq on my unit. I keep getting an error message for outside noise.
I am running in 3-way active mode. Internal amp is turned off. I did reset the head unit and tried again and still had the same error. I am performing the auto-eq in a very quiet closed garage.
Any suggestions or help is greatly appreciated.
By AudioFiLe
So i just bought 2 Stinger voltage meters for my XS batteries to keep tabs on the volts and i am hoping to mount them on the side of the dash in my ford ranger. i dont have the tools or skills yet to do a whole fiberglass mold so i will be using a dremel to cut out 2 square holes to flush mount the 2 meters. the system i am getting will be hitting at least 140db so i need to figure out what adhesive (or whatever else i can use) to keep the meters stuck to the inside of the dash panel without having to use fillers.
anybody got any advice how to keep these things in place?
Recent YouTube Posts
