guamgsx
older Q with newer Q
I have a older dual slug Q and I want to run two Q's now. Would I run into any problems running a newer Q with athe older one in a ported enclosure?
Email fi directly for a definite answer, but I believe you can run the older Qs with the newer ones. Someone a while back had the same question, maybe you can dig it up with the search.
they came back with a no,  has to do with different motors and what not
the reason i was asking cause i have an 07 q15  looking for a match
No. Okay, well it depends on what you mean by can. You "can" run a Kicker L7 with an Fi Q I suppose, just not a good idea. Anything that creates a difference in t/s parameters is a no no for drivers playing the same frequencies. Even worse if it shares airspace.
I figured that would be the case. I just can't seem to find the specs for the older Q. I love my Q and came across a good deal for second but its a newer one. Even the power handling is different.
I would sell your older and buy the newer single slug motors as they are not hard to find as of right now.
or recone the current sub to a larger size.
I already new that, but sometimes new versions of the same driver are close enough that they can be used together.
anyways glad you got it figured out OP.
I ended up buying the newer one. The guy sold it to me for 175 and I could pass it up. Now to find a matching newer one or wait to see if it goes on sale for black Friday.
