Recently Browsing 0 members
Recent Topics
- 19 comments
- 320 views
- 3 comments
- 75 views
- 398 comments
- 33,297 views
- 4 comments
- 155 views
- 2 comments
- 733 views
- 5 comments
- 1,582 views
Similar Content
By antoinez28
My goals to be able to hit a 155.0
With a window line box and being able to demo low note and burp high notes like in the 50s
My build came a long way ...
Working on getting that iPhone 6 slow mo cam is great
https://m.youtube.com/watch?v=VOoaSMFNRbw
By antoinez28
I have for sale two crescendo bc 2000 for sale both are about 1 1/2 years old good deal power by two g31 batt juciebox, and crescendo logic...pushing 2 18" ethos strapped at 2ohm never seen below 12volt...I had to push them....got warm in this hot Kansas City weather...both will come with bass noobs and one with owners books the other might be lost during a move with both boxes from crescendo...I love these things they both went to db-r for repair but nothing major I had a bad ground and thought I blew them both
Crescendo BC2000D
Stable down to .5ohm on strong electrical.
Up to 16.8v capable on BC2000
Remote Bass/Gain knob with Clipping Indicator.
Custom tooled, proprietary Multi-piece Thermal optimized Heatsink with patent pending interlocking slide-out CNC engraved top plate.
2 stage copper anodized removable top plate.
Silver plated high end hard-wired Tiffany RCA inputs and oversized 1/0 Power/Ground Inputs for efficient current transfer.
Overbuilt Power supply with heavy copper traces and Military spec PCB/heavy duty standoffs for extreme vibration resistance.
Manufactured using some of the highest quality and most reliable electrical components, with many 3% tolerance components throughout.
Full 4-Stage Intelligent protection Circuitry 1 Year/1ohm comprehensive warranty with 2 year/.5ohm optional extended warranty available.
Rated Power Output(RMS)
Clean RMS power on 13.8v standard electrical system:
Ohm Load
BC2000d
1ohm
2250
2ohm
1100
4ohm
700
Dimensions: BC2000: 16"L x 2.75"H x 9.5"W (at widest point)
I want 550.00 for the pair or 300.00 each shipped no lower
I'm upgrading to a bigger amp dd-m4a
By antoinez28
So I'm been on the web looking at different types of 5k amps that are linkable amps, so I can upgrade my current amp set up...I'm looking for a amp out of these new or used- dd m4a, sundown audio 4500, crescendo bc5500, dc audio 5k, ampere audio 5000.1. It has to be able to do around 3800-4000 wire down to 1.3ohms.
Running 3-18s DSS ethos box is in the works....
Electrical is dual alts stock will run the truck, mid, and highs the singer 270amp will run only for the battery bank. 4 juice box blackcherry battery back, two runs of 1/0 wielding wire.
( would like more batts if space would allow)
( playing music daily and burbs on comps)
I'm not looking for a father and son conversation here just wanting to know which amp would be better suited for my set up that's all thanks for reading.
By antoinez28
So I'm in the Midwestspl local and I'm going to change my class to nationals and was wondering if any body on here is from the same group "Midwestspl" that in the basic 4 class that can tell me how tall my box can be I know it to the window line but my 2005 tahoe has to different window line heights the side window is higher than the back hatch window...more ? To come once that one is answer.
Recent YouTube Posts
