frogcase2002
05 sable 2 zcon 18s on 10k in b-pillar walll
Going to try and get some videos today. Hard to find a place where I can play this loud in one spot lol . . Hope videos even look good. Im really surprised how solid the car is. It dont flex like you see vehicles on youtube doin (which I like) . Maybe I can try a hair trick or floatin stuff in the window
Well stock alt finally went out lol I was waitin for it . Its only be charging in the high 12s for a while now. Luckily I was close to the shop when it did and made it back  going to try to make this ohio gen that I have work today
This is stock next to the ohio gen
Thinking ill just have to use mass washers or some kind of spacer to fill in where the stck alt would have went over to . . If you can tell what I mean from the pic
And on the othe side will just have to space here to make them the same size
Then I got to worry about the plug
That's how I was planning to use my buddy's as my second on the jeep from his durango. Only reason I havnt messed with it yet is not sure if the stock wiring can handle both at once. Or if I need to regulate one just for the system with one of the transpo boxes. I don't use ac, so all I need to do is fab up a bracket to mount the second where the a.c. pump is and run a smaller belt.
Got the alt to fit perfect but couldnt figure out the wiring . . Going to have to call ohio gen tomorrow and see what wires are on this plug
Actually got it to work
Havnt left the shop yet . Set it to 14.9 so ill check how it holds in a few once I leave
Havnt seen this high in a long time lol.  Its nice
Didnt see under like 13.8 on the way home going full tilt . . But the amp is really far down from just having the stock alt on before . . Ill do some testing tomorrow . Turn up some shit lol
Turned the gain up . Forsure can tell a difference. And still took like almost a whole song to even see 13.9 . Holding voltage like crazy . .But dont know how much power im really putting to the zcons though
Sucks right when I got the sub part of  the build done all the audio show are done for the year around me lol . Guess it gives me time to get everything perfect
Looks real good! What gauge/how many runs wire are you using from the alt to the trunk? I'm picking up a 240 amp alt shortly for the taramps 8k and I have no idea if i need more than 1 run of 1/0 ofc...etc
I got 2 runs of 4/0 power. Probley over kill but I always like to leave room to upgrade. But runnin that much power I would at least have 1 run of 4/0 or 2 runs of 1/0
Man need tweeters bad . These 3 dollar one are not cuttin it lol. Just cant put much power to them and the mids are drowning them out
Has anyone had a problem with the bass turning the volume knob on your head unit? Need to figure something out. Made my tweeters pop a couple times yesterday cause my volume went from 30 to 34
151.5 or over from 25hz to 55hz
And never seen below 13.2 while I was metering
