Recently Browsing 0 members
Recent Topics
- 3 comments
- 68 views
- 398 comments
- 33,235 views
- 18 comments
- 308 views
- 4 comments
- 142 views
- 2 comments
- 728 views
- 5 comments
- 1,571 views
Similar Content
By musgrove
I'm nearing the finish line in an installation that includes a new HU with FT/RT, FR/LT RR/RT RR/LT, and a SUB output, plus an unmarked, unidentified in the manual, RCA output on the back of the HU next to the SUB output.
I have a 5 channel amp that has Channels 1(white), 2(red), 3(white) and 4(red) marked clearly on the amp, plus a SUB RT(white) and SUB LFT(red) input, all input by RCA.
The same amp has 4 sets of output terminals, 1 each for + & -. It also has 2 terminals for the sub (+ & -), which connects to the sub on R &L posts.
So, first question:
How do I run a cable from the HU, which is 1 RCA connection, to the AMP, which has both LT and RT RCA input connections?
Second question:
I also have the White, Grey, Green, Violet (+&-'s) hooked up from the HU to the wiring harness that goes to the speakers. The reason for this was that I have six speakers placements: 2 6.5" in the front doors, 2 6.5" in the rear doors. In the dash, I removed the tweeters that were in a plate and replaced them with Infinity Kappa20's midrange speakers that have bandpass crossovers that handle 550hz-7Mhz hooked up.
Just to confuse things more, The manual for the amp shows The channel 1 speaker attached to the channel 2 output terminals(+&-) and the channel 2 speaker (+&-) attached to the channel 1 terminals. Channels 3 and 4 are where I expect them, 3 & 4. And then again for the SUB it has + and - terminals to go to + & - posts on the SUB.
I've routed every plug in every location and checked each speaker, one by one by changing the fader/balance in different combinations to determine what's going on.
What I sense I'm doing wrong is that I'm wiring RCA cables with both RT/LT wires into the AMP to the HU when both only want a single signal cable each going into each jack. One single wire each that somehow is carrying both the Positive and Negative in it, versus a double speaker wire that goes into a positive/negative RCA male connector.
So that leaves the sub with one single output HU going to the AMP which has a R(white) and L(red) female connector. And then the 5th channel +&- going to the +&- on the SUB input.
The reason I have the HU output speaker wires (white,grey,green,violet) going to the speakers is because of the Dash Unit speakers. They're tapped into those 4 in the wiring harness where I can't get to them, but run from the HU from 4 wires to 6 different speakers). Again, the dash speakers are 2" Infinity midranges with bandpass crossovers connected to each which came with them. I just noticed they are 2.5 ohm, and everything else is 4 ohm, which is worrisome.
Is there a wiring genius out there that can understand what's going on and tell what I have wrong? There's also a whine coming from the front right dash speaker and possibly the right(passenger side) door speakers. I have the power cable far from the speaker wires on either sides of the vehicle. But I'm sure it has with the larger wiring issue at hand.
Any and all help is greatly appreciated. This is a crazy puzzle. Here's a diagram I made to make it more visual:
By jones82joshua
Been registered since 2010, inactive on the forums(used mostly for lurking, reading up on things). Only slightly more active on ****. Audio has been my (oft neglected) hobby for the better part of 20 years.
Trying to scratch my itch again, after close to a year of happily owning two 15" XCon's on a SQ 1200(.25 ohm) I decided to throw a second 1200 on them, strapped at 1 ohm. Needless to say, they started to come alive, and my itch got worse, so here I am.
I mostly listen to metal, occasionally house/techno, a little rap(a guy has to demo once in a while!)
Previous setup(last vehicle, about 3 years ago):
2001 Monte Carlo SS (Not measured, guesstimated around 145+)
+.5v booster (15.1 charging voltage)
XS Power D3400 in trunk
Pioneer 80PRS, active
Planet Audio BB175.4 @ 4 Ohms
CDT HD-M6 6.7", MB Quart tweeters (can't find info)
Crescendo Audio BC3500 @ .33 ohm
3x Sundown Audio Zv3 10"
~5 cubes tuned to 37 hz
Current setup: (141.0 on single 1200, not measured yet on both)
2005 Cadillac SRX 4.6
Planet Audio BB175.4 @ 2 ohms
Infinity 609cs component system
2x Soundqubed Q1-1200.2 strapped @ 1 ohm
2x SSA XCon 15" D1
TL enclosure designed by So Low on ****
XS Power D3400 ~1 ft from amps
Upgrades planned or considering:
Swapping out Infinity components with Silver Flute 6.5(4 ohm) and SB Acoustics SB29RDC Ring Dome tweeter(4 ohm). (Already owned)
Swapping out BB175.4 with a different amp(Incriminator IA6.4 or Crescendo C1100.4)
Upgrading to 5k+ and possibly a third XCon.
Anyways, I would like to say thank you to the community, and SSA, for being so helpful and informative.
By Shogen
Like the title says.... Getting rid of this bad boy, has all accessories (even the GPS antenna) except USB wire which you can pick up any where (USB extension cable).... I will let this go for $675 shipped....
Price: $675
PAYPAL ONLY
Shipping within continental US only
***MODs I took photo last night but had issues getting onto the PC hope yesterday date ok***
Buy with confidence, long time member of the community...
Recent YouTube Posts
