I need help concerning a recone on my Audiobahn made Dub1200 12in subs. Im not new to car audio but im new to reconing. So please don't tell me hiw bad they are etc. Just practicing recones.
Question is will a Sundown SA 12 Recone fit this sub.
Audiobahn DUB1200 12" Dub Series
1400 watts peak power handling
700 watts RMS power handling
Chrome-Plated Aluminum DUB grill included
Wooden gift box included
Non-Pressed, Non-Transfer Paper Woofer Cone
KM3 Coated for virtually no cone distortion
Can operate at 2 ohms or 8 ohms depending on wiring configuration
Multi-connect lug lock terminals
PHAT 2" Foam Surround
2.5" Dual 4 ohms Voice Coils
Efficiency: 92.7 dB
Frequency Response: 20Hz - 500Hz
Fs: 31.2 Hz
Qts: 0.6
Qes: 0.67
Qms: 6.23
Xmax: +/- 12.5mm
Vas: 1.8 cubic ft. (Not volume of box)
Woofer Magnet Displacement: 0.18 cubic ft.
I doubt you can get a recone, considering audiobahn went out of business. Now you might contact psi, they might could recone it, but it want be the exact same sub, it will be more of a Frankenwoofer, with different T/S parameters.
It's hard for us to know what will fit the woofer motor because of gap and all the other jazz that is taken into consideration. If you would like to PM me I can help get you on the right path without promoting other companies that don't pay for support here at SSA. Now with that being said sell your motors and recone and jump on some SSA woofers!
Unless you can find exact drop ins it will be a complete waste of money.
