Bresch
Ideas for my System
///M5    2,198
1 hour ago, SS Teacher said:
Finding amps that run at .5 ohm is very hard on electrical as a daily driver.
...and pointless
Billy Jack    146
5 hours ago, ///M5 said:
...and pointless
Not if you already have subs that can only be ran at 2 or .5 ohm but yea I wouldn't aim for that.
Randal Johnson    354
I'd much rather have multiple amplifiers at higher ohm loads verses one amplifier at lower stressing ohm loads.
Just Saying
Bresch    0
On ‎3‎/‎7‎/‎2017 at 4:49 PM, ///M5 said:
Doing a 3 way active as your first step isn't something I would recommend.
6.5" midbass won't be much of a midbass.  If you are in the mode of a 3 way...I'd try like hell to fit something bigger.
As for the rears, those locations are useless.  Don't use them.
Could you make some suggestions for 8" midbass drivers you prefer for a three way active set up?
///M5    2,198
Sure but they will vary like hell depending on locations, processing, and mounting possibilities for other drivers.  The beauty of active is that you can optimize for your install which is far from possible with off the shelf passives.  Hell off the shelf and car install are ridiculous in general...
frogcase2002    226
I would look more into a 2 way front stage . . You would be surprised how good it can sound even with not to good of drivers
///M5    2,198
All car audio sets are full or ridiculous compromises...it is easy to surpass them.  Add to that the uber so cheapo crossovers that aren't designed in situ and they are nearly pointless
Bresch    0
Posted (edited)
I definitely agree with you on that one. The passive crossovers I had been using for my Rockford fosgate tweeters had melted casings when I replaced the system with an active crossover. Thank goodness the tweeters were fine, but the smell was what tipped me off.
I understand the push for simplicity and the two-way crossover, I'm basically running one right now with the removal of my rear 6x9's. My next step is sound deadening for the doors. Then I want to add an 8 inch to boost the power afterwards. I'm considering putting the 8 inch in the doors next to the driver and passenger seats of the car. Does that help narrow down your list of recommendations?
Edited by Bresch
///M5    2,198
You have to match the full set. Need to know ALL the mounting options, etc...
Bresch    0
Once I sound deaden I'll get back to you on that. First I want to see the level of improvement that my door speakers will experience with sound deadening, new and more appropriate mounting, as well as speaker tweakers.
Thank you for your help, stay tuned.
frogcase2002    226
Couldnt really see the speaker tweakers doing anything
Bresch    0
Please elaborate, why exactly would you think that?
frogcase2002    226
Have never experienced my self but have heard from a few people that have tried them that they couldnt tell any difference after using them
Bresch    0
Posted (edited)
So taking this into account here is my idea.
First, there are factory locations that are about two inches above ankle level in the bottom left corner of the door (facing the door). I could make a baffle of my own and mount any size speaker to that area, there is enough space. I also have room for door pods if I heavily modify my door. There is room more towards the center of the door for a door pod at the same height. I would rather not mount any speakers above this point as having speakers blasting any nearer to ear level sounds like a bad idea, but you may have a different opinion and I'm all ears (literally :D). Not only that, but there is some cool OEM carpet set in the doors I'd like to keep.
I do not believe I have enough room for a kick panel (at least safely placed away from feet).
Now for the speaker(s) in question. Since I already have a couple of rockford fosgate tweeters that are off axis and which I have tuned for a nice bright sound, I was thinking about replacing my current 6.5" drivers for these 8" midbass oriented drivers: https://www.amazon.com/Rockford-Fosgate-PPS4-8-MidRange-Speakers/dp/B00M34TI36/ref=sr_1_3?ie=UTF8&qid=1491769285&sr=8-3&keywords=PPS4-8+rockford+fosgate. The frequency response range is about 80-5,000 hz for these speakers and their SPL numbers are about where I want them (94.5).
P.S. Just in case the url isn't stable it is the PPS4-8 offered by rockford fosgate.
Now there is an alternative within the same company for 10" speakers here: http://www.rockfordfosgate.com/products/details/pps4-10. This speaker name is PPS4-10. It has a sensitivity of 96 with 40hz-4,000hz.
Keep in mind that my subwoofer will be an ICON and the current tweeters are these: http://www.rockfordfosgate.com/products/details/p1t-s.
The tweeters have a sensitivity of 90, and that's plenty loud for me as far as tweeters go. I actually have them backed down a bit, but they are loud enough. Their frequency response range are as follows: 3.5kHz-22kHz.
Currenly my 6XS Audiocontrol external crossover has a crossover point for my front stage. I have the point set as thus:
250hz low pass and 2,800 high pass. I know you guys know the details, but I'm gonna go ahead and explain it so you may have the opportunity to correct me if I am wrong. 250 hz is the lowest frequency that the midrange woofers will ever see and 2,800 is the highest they'll see. Consequently, 2,800 hz is the lowest the tweeters will see. I can change this to fit any application, so depending on the speaker... I was gonna lower the 250 hz to 63 hz for the 10" or so with a 24 db cut off. I figured a steep slope will be appropriate since the ICON seem to have a solid ability to take over from there.
For the 8" I was gonna make a 80hz with a 24 db cutt off as well, however I'm not familiar with the ICON enough to make that call. I feel as I write, the 10" is a much better pick. However, I'm open to suggestions.
Thoughts?
Edited by Bresch
///M5    2,198
First thing you need to shop for is a crossover.  No way, no how are you going to get a 3 way to work with the Audio Control you have.
Next step is to figure out how much of a midbass driver you can use...and to stop looking at ANYTHING car audio specific.  Then if you want nothing low, you should decide if you are willing to build kicks.  As a first install of a 3 way I would recommend that as it will simplify the crossover setup.
All that being said, I'd still really recommend nailing a 2 way first.  It will sound better as it won't be the equipment that limits the install.
Bresch    0
Posted (edited)
So I replaced both my Infinity kappa 120.9w 12 inch subwoofers with an SSA ICON 12 inch subwoofer. I am seriously impressed. In a small sealed enclosure this beast gets louder than both and is more accurate. This is out of the box. The Infinity subwoofers had a year of break in for comparison.  I couldn't believe the stiffness either. Just enough give to convince me that this sub wasn't frozen.
 I've only had it for three days so far. This sub has a noticeable change of performance each day. The lower notes have the most change, becoming more prominent with every session. The sub excels in playing lower frequencies around 25 hz to 63 hz which is honestly my sweet spot. I listen to a lot of EDM and Hip Hop. However, jazz and orchestral pieces sound just as well.
This monster is fast. Every bass note, every drop, every phase, and every punch is felt precisely where she wants it. This sub knows how to recapitulate the files I'm feeding her. Clean is the new sexy and this sub is very sexy. I'm a very happy customer.
Qualitatively, the sub feels like it has solid thermal handling. I play the subwoofer for two to three hours full tilt and she gets moderately warm to the touch. I don't have an actual readout as to the temperature, but imagine touching a puddle of water after a heavy rain followed by a sunny day.
1 more please?
Edited by Bresch
Jay-C76    327
Thought exactly the same thing when I uncorked mine years ago. One of the most accurate subs I have ever heard. Nice choice!
  • Recently Browsing
