edouble101
Excellent condition Rockford Fosgate Power amplifiers
I am selling my excellent condition Rockford Fosgate Power amplifiers. The T1500-1bdCP was from Rockford Fosgate, the T600-4  and T600-2 were bought from Crutchfield.
T1500-1bdCP - $400 shipped
T600-4 - $350 shipped
T600-2 - $350 shipped
T1500-1bdCP http://www.rockfordfosgate.com/products/details/t1500-1bdcp/
Number of Channels: 1
Rated Power: 1000W x 1 @ 4-Ohms RMS
1500W x 1 @ 2-Ohms RMS
1500W x 1 @ 1-Ohm RMS
Total Power: 1500 Watts
Dynamic Power: 1320 Watts
Bridgeable: No
Efficiency (average): 86.2% @ 4-Ohm
74.6% @ 2-Ohm
63.0% @ 1-Ohm
Crossover Controls: Low-Pass (LP): 35-250Hz 24dB/octave Butterworth
Tone Controls: Bass: 0dB to +18dB @ 45Hz
Infrasonic Filter: -3dB @ 28Hz 12dB/Octave
Signal Input: Low level: 1 RCA pair
Signal Output: Low level: 1 RCA pair
Power Input Connector: Block
Power Wire Gauge: 4 AWG
Speaker Output Connector: Screw terminal barrier strip
Speaker Wire Gauge: 8 AWG to 18 AWG
Heat Sink Type: Cast aluminum
Cooling: Convection
Remote Controls: Optional Remote Punch EQ (overrides built-in Punch EQ)
Visual Indicators: Power
Thermal
Protect
Circuit Topology Class: Class bd
Frequency Response: 20Hz to 250kHz +/- 0.5dB
Shipping Weight: 14.35 Lbs. (6.50 Kg.)
Dimensions (HxWxL): 2.14 x 8.14 x 14.91 (in)
5.42 x 20.68 x 37.86 (cm)
T600-2 http://www.rockfordfosgate.com/products/details/t600-2/
Number of Channels: 2
Rated Power: 200W x 2 @ 4-Ohms RMS
300W x 2 @ 2-Ohms RMS
600W x 1 @ 4-Ohms bridged RMS
1-Ohm x 2 Stable
2-Ohm x 1 bridged Stable
Total Power: 600 Watts
Dynamic Power: 229 Watts x 2 @ 4-Ohms 0 degrees Res
369 Watts x 2 @ 2-Ohms 0 degrees Res
Bridgeable: Yes
Efficiency (average): 71% @ 4-Ohm
68% @ 2-Ohm
Crossover Controls: High-Pass (HP): 50-500Hz 24dB/octave Butterworth
Low-Pass (LP): 50-500Hz 24dB/octave Butterworth
Tone Controls: Treble: 0dB to +12dB @ 12kHz
Cooling: Convection
Thermal
Protect
Circuit Topology Class: Class A/B
Frequency Response: 20Hz to 20kHz +/- 1dB
Shipping Weight: 12.15 Lbs. (5.51 Kg.)
Dimensions (HxWxL): 2.14 x 8.14 x 13.66 (in)
5.42 x 20.68 x 34.69 (cm)
T600-4 http://www.rockfordfosgate.com/products/details/t600-4/
Number of Channels: 4
Rated Power: 100W x 4 @ 4-Ohms RMS
150W x 4 @ 2-Ohms RMS
300W x 2 @ 4-Ohms bridged RMS
2-Ohms x 2 bridged Stable
Dynamic Power: Front Channels
139 Watts x 2 @ 4-Ohms 0 degrees Res
236 Watts x 2 @ 2-Ohms 0 degrees Res
Rear Channels
140 Watts x 2 @ 4-Ohms 0 degrees Res
Bridgeable: Yes
Efficiency (average): 70% @ 4-Ohm
64% @ 2-Ohm
Crossover Controls: Front High-Pass (HP): 50-500Hz 24dB/octave Butterworth
Front Low-Pass (LP): 50-500Hz 24dB/octave Butterworth
Rear High-Pass (HP): 50-500Hz 24dB/octave Butterworth
Rear Low-Pass (LP): 50-500Hz 24dB/octave Butterworth
Tone Controls: Front Channels - Punch EQ
Rear Channels - Punch EQ
Signal Input: Front Low level: 1 RCA pair
Rear Low level: 1 RCA pair
Signal Output: Low Level: 1 RCA pair
Cooling: Convection
Thermal
Protect
Shipping Weight: 12.00 Lbs. (5.44 Kg.)
T1500-1 is SOLD
