Joey laughlin
Tunning Recommendations
Posted (edited)
I have two DC audio xl 12s just built birch box after diplacment im setting at 4.03 cubes have good electric running skar 4500 so they are seeing 2200 to 2500 rms each here were i need a little help they will be in the back of 2014 Lincoln navigator  i have material for 2 4” round ports were should i face subs and port location and whats the best tunning for these subs
Edited by Joey laughlin
I’m no enclosure designer, but most setups I’ve seen with a simple pair of 12s is sub’s back, port back with a 36ish htz tune.
What are your goals?  That will effect tuning.
Everyday ground and pound i listen to alot of bass boasted tunes
If they are lowered I would account for that too.
If you aren't putting the vents external to the cabinet you need to know their volume as it will subtract from the enclosure volume.
