Joshdashef
Honda Civic Coupe 08 2x2k???
Hello and welcome to my daily headaches! I'll start this build log off with my past setup, my current, and finally update throughout December as I work on probably the furthest this little Civic will let me go.
My instagram: https://www.instagram.com/joshdashef1/
The Past Build:
Head unit: Pioneer 80 PRS
Mono Amp: Rockford Fosgate Prime 750.1
Subwoofers: Rockford Fosgate P3D4 12" (two)
Kicker 4 gauge amp kit OFC
Stock Electrical (alternator included)
Did do the big three sometime between here and current build
Prefab Box: Q-Power Box (Dual 12s)
Tips: Tesa taping RCA's, Marking RCA's Low/Mid/High or similar,
Big Three with loom. Wire was Sky High 1/0 OFC with some 1/2" loom I believe. Old military style terminals (DO NOT USE THESE) they cracked my battery eventually.
tumblr_p86ktohIr51xsodn1o3_540.jpgtumblr_p86ktohIr51xsodn1o2_540.jpgtumblr_p86ktohIr51xsodn1o1_540.jpg
Work to get to current build: (a lot from 2018)
Day 1: Stripper Time
Looming RCAs (Rockford 20ft or 16ft twisted with some Tesa Tape):
My tip for those doing anything similar is to utilize a loose zip tie as a tool to control the unwrapped RCA cables
I also recommend marking your RCAs so you can distinguish between them on the other side!!
Sky high dual fuse holder (doesn't fit larger gauge wire easily...
Bass Knob Mounted by driver side knees.
Sound Deadening, going for some resistance to rattles here:
Dual run of Sky High 1/0 OFC. Flexible to a point wire, but very over-sized so be careful with what termination you buy!
Best damn tool I have ever bought for getting through a firewall.... Unibit buy it. (comes in different sizes!)
Also DD-1, can be found here:
If you plan on setting gains, get one of these (or an oscilloscope)
Drilled basically where the clutch would be if I had standard trans. Added rubber grommets off amazon, use a little petroleum jelly to help coax the wire through if you have trouble.
Planning Wire run to rear: Loomed in same 1/2" loom and some zip ties/tesa tape when needed.
Crossing into middle of car under drivers feet. Yes I can feel the bump, but it is no where close to where I rest my foot daily driving. Also ran from near center console to driver side rear seats, eventually into trunk on driver side.
Planning out battery location. XS Power D3400
Picture of the god awful moxel plugs using a tiny wire camera.
Pics on engine bay side of wiring through firewall
Work to get to current build: (a lot from 2018)2
The switch to SMD fuse holders. I love these things. Absolutely worth spending the extra cash for each of these!
Also the dealer I bought them off of, AudioFanaticz, threw in some goodies!
Great Fuse holders, but bad mounting on my part... Definitely will address this issue this month!
Rear Fuses for reserve battery
Mounted to side wall, then insulated with some tape just in case.
tumblr_p8wd1z8iVg1xsodn1o2_400.jpgtumblr_p8wd1z8iVg1xsodn1o9_400.jpgtumblr_p8wd1z8iVg1xsodn1o8_400.jpg
Grounds color coded with tesa tape. Used a DMM for finding a suitable grounding location. This spot surprisingly had low resistance!
Building my first ever box:
My designs came from JeepandBass: https://www.jeepandbass.com/box-designs
If you are just getting into the game then I recommend having someone else design your box. Then design your second box like I am doing!
Bought two sheets of MDF
Portable table saw for long cuts
Wear protection! No jokes this stuff is not good for your lungs or eyes, so gear up and clean up.
All cut out
My Hardware: Brad Nails to assist with holding pieces for follow up coarse threaded screws
1" screws and brads | 45s
1 1/4" screws and 1 1/4" brads | Baffles connection between layers
1 5/8" screws and 1 1/4" brads | Most joints for the box excluding the connection between the baffles and sides/port
2 1/2" screws and 2" brads | Baffles connection to sides walls/port walls
Tip for cutting circles in a MDF!
Screw into a scrap length of wood the size of your subwoofer diameter plus some. Then mark out your cutout diameter by using a ruler to mark where your next screw will go. After that you now have a template you can use to score into any wood for a speaker of the same cutout diameter!
After doing this I glued on the second layer behind each side and screwed it in to let dry over night.
Put together the sides of the box and back wall
After the baffles glue had dried (23 hours). Cut out the scored circle with a jig saw (router would be much nicer and easier, but more expensive for entry level)
Smooth with sandpaper
Test fit
Planning:
Some sanding on inner port wall to knock off hard edges
tumblr_p97tneNiwt1xsodn1o5_400.jpgtumblr_p97tneNiwt1xsodn1o6_400.jpgtumblr_p97tneNiwt1xsodn1o7_400.jpg
Planning out screw placement and panel placement on top piece
 Notice the overhanging baffles. Yeah someone fucked up! I decided to leave them since I was dying to hear it, but could have just as easily sanded them down.
Final Product:
tumblr_p99qdtM1O41xsodn1o3_400.jpgtumblr_p99qdtM1O41xsodn1o2_400.jpgtumblr_p99qdtM1O41xsodn1o1_540.jpg
Now thats a big ass box... This required a lot of coaxing to fit, but after turning it then putting it in... she fit.
Work to get to current build: (a lot from 2018)3
Start on amp rack and battery mount with scrap MDF and some cardboard cut to fit on driver side little cubby.
Hooked up battery fuse holder to main runs. Hate myself for this fuse holder placement without reinforcement!
My little MDF box for a D3400 and some shiny aluminum bussing. Enclosure was glued then has two screws for removing the battery.
Planning power runs for amps
Another idea that works but could stand a redesign. Horizontal fuse mount. At first it had tons of play in it but after adding the top piece that held it upright, it mostly stays as is.
Wiring P3D4 12s. 10 gauge sky high wire
Loved these grills that Rockford has
RCAs ran to rear. Ended up with a lot of excess cabling.
Finally. The moment I had been looking forward to for days after days of work
Electrical tape for the sides that are closest to each other at the amp terminals. Both + and -
The setup v1
While tuning and testing this I ran into a voltage problem, low 13s. I decided to fix it
Mechman 240A Alternator in Blue!
Heres a side to side for laughs
Old versus new. 1/0 ran from alternator + to battery (fused), and alternator - to battery negative. Whoop Whoop!
Installed 4 channel, RF P600x4. Front speakers not hooked up yet.
Connecting up some LED's off amazon by soldering on some wire and terminal for my Blue Seas System Fusing: https://www.amazon.com/Blue-Sea-Systems-Blade-Block/dp/B001P6FTHC/ref=asc_df_B001P6FTHC/?tag=hyprod-20&linkCode=df0&hvadid=312128389336&hvpos=1o1&hvnetw=g&hvrand=16344823841222530695&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9011457&hvtargid=pla-383472770805&psc=1
LED's for fun
Edited by Joshdashef
My Volt Meters:
Stinger Digital Volt Meter - quick glances
Blue Seas Analog Volt Meter - shows dips in voltage that Stinger doesn't display
Back
Diagram
Calibrated with DMM
Work to get to current build: (a lot from 2018)4
Adding some Dynamat to the doors and behind speakers, thinking of comparing this stuff to some SecondSkin deadener on the rebuild.
tumblr_p9vysu5Tnu1xsodn1o5_540.jpgtumblr_p9vysu5Tnu1xsodn1o4_400.jpgtumblr_p9vysu5Tnu1xsodn1o3_400.jpg
Trying to stop some plastic rattle with Tesa Tape
Ran speaker wire to rear
Old Tweeter mount, Florida = melted glue whoops. Should have used some JB weld instead...
Noticed the plastic rings on the inside of the panel were not able to be seated all the way back because of the adapter mount. Decided to cut it shorter and apply some foam tape.
Applying some SS damp rope. I definitely want to redo this mounting bracket with some ABS plastic and some deadener.
tumblr_pauz44eqjt1xsodn1o6_400.jpgtumblr_pauz44eqjt1xsodn1o8_400.jpgtumblr_pauz44eqjt1xsodn1o9_400.jpg
Deadening license plate and trunk lid pieces
tumblr_pbfgpwBfUy1xsodn1o3_540.jpgtumblr_pbfgpwBfUy1xsodn1o5_540.jpgtumblr_pbfgpwBfUy1xsodn1o4_540.jpg
Fixing a side panel with zip ties and a drill
Went back and sanded alternator connection
Replaced cracked wally world battery with XS D5100R
Switch to SA 12s from P3s
Yes I never finished this box, but I never planned on keeping it. I think if I take it out i'll sand down the imperfections, and wrap in some carpet. Might end up putting it in my friends car too :dancing:
The Rebuild 2019/2020
Finally have reached the point I want to redesign everything. I'll be tearing out everything in the trunk and redesigning the box for a single 15, two DC 2ks, same 4 channel amp, and better electrical. So far I have ordered a 1000 Farad XS power superbank, but I think I will end up replacing the D3400 with a XP 3000 or two.
Wanna drop a plug to the https://store.soundsolutionsaudio.com/ for their excellent customer service and extended Black Friday deal on both my second DC 2k and XS SB1000-31. Thanks Guys!
SP4 v2+ 15" Dual 1 ohm | 7" Gloss Carbon (Ice Blue) | 4 spiders | Cooling | Hybrid Leads |
Packaging is 11/10, also heavy AF
Thanks for sharing.
Ive been looking at the SP4 as well. What made you choose that over the BTL?
3 hours ago, Gunk said:
Thanks for sharing.
Honestly, the hugely positive reviews of it. I’m sure the BTL is just as good but if I’m remembering right each serves a purpose. I decided the v2+ after discussing it with some other users seeing as it offers higher motor force (Better for ported enclosures).
I planned on getting a driver orientated towards daily driving with great output 30-40hz. I am still juggling whether to go for a tuning of 28 or 30-32. SP4 fit the bill.
4 inch coil is less efficient perhaps but I think extra thermal capacity is a nice trade off. My commutes an hour to and an hour back so plenty of time to get her moving
Sounds good to me. I read somewhere that the SP4 is a bit more musical than the BTL as well.
:woot:love the progress man
XS SuperBank came in from SSA store today, look at the size compared to that 18650! Just waiting for my 2k to be shipped now.
- New electrical will be much of the same; Mechman 240a / dual 1/0 runs / D5100R underhood / SB1000-31 / and either a D3400 or I'll switch over to XP3000 or two.
