Check out these other great forumsSoundSolutionsAudio.comAudioAddicts.netCarAudio-Forum.comCarAudioResources.comHomeAudioForum.net
Welcome to SSA Car Audio Forum
Register now to gain access to all of our features. Once registered and logged in, you will be able to create topics, post replies to existing threads, give reputation to your fellow members, get your own private messenger, post status updates, manage your profile and so much more. If you already have an account, login here - otherwise create an account for free today!
Modified Show | Custom Cars, Car Audio and Models
Proudly Selling Mechman Products
SAZ-3000D POWER TESTING
  • Please log in to reply
82 replies to this topic
#61
platnum accord
platnum accord
    Member
  • Members
  • 366 posts
bump for updates?
2000 4dr Gold Honda Accord.-----223000Km's, and still running strong
Wiring: 2/0 Guage Welding Wire, + and - , 1 run.-----------HU: Sony Xplod .
Rca's: Scosche Industries.-------------------------------------Subbage: 2x Clarion PXW1552 .
Box: 7 Cubes total tuned to 29hz.----------------------------Amp: Sundown Aduio SAZ1500D.
Speakers: PG QX165 Components----------------------------Lighting: Neons tuckked under the dash.
Battery: Optima Red Top Group 35.---------------------------Alt: Dom Iraggi 200 amp ~70 at idle.
#62
sundownz
sundownz
    SSA Elite Level 2
  • Vendors
  • 7,927 posts
  • Gender:Male
Chad Hicks measured his at 2500 watts @ 2.5 ohms with 16 volts.
If I can modify my test box to hold the DD 9512s that I have I can get "somewhat" 12 volt ratings. My voltage will drop, if I'm lucky, to 11 volts or so... quite possibly less. If I get some time this weekend I'll try to round up a few more batteries to hook up to the trusty Pyramid power supply :)
- Jacob Fuller
- Owner, Sundown Audio
- Sundown Audio on FACEBOOK
- Associate, Stereo Integrity
#63
lilmaniac2
lilmaniac2
    Regular Member
  • Members
  • 571 posts
  • Gender:Male
Posted Image
<img src="http://www.teamssaud.../chadhicks.jpg" border="0" class="linked-sig-image" />
#64
lilmaniac2
lilmaniac2
    Regular Member
  • Members
  • 571 posts
  • Gender:Male
another note, the sub ran out of voicecoil before the amp ran out of juice, theres much more in there :)
#65
sundownz
sundownz
    SSA Elite Level 2
  • Vendors
  • 7,927 posts
  • Gender:Male
Alrighty... so I abused the infamous Pyramid power supply a bit more today. Same setup I've been using for other clamp tests:
Pyramid 50 Amp Power Supply
8 AWG from supply to batteries
Kinetik 2400 Battery
Duralast 1000 CA Battery
2 AWG between batteries
4 AWG from batteries to amp
Fluke AC current / voltage meter
Sears DMM
Measurements:
65.8 volts
49.2 Amps
1.33 ohm calculated rise from 0.6 ohm DCR **
3237 Watts
14.4 volts rest dropping to 10.75 volts
** - Rise was higher than when I tested the 1500D, it was 1.08 ohms for that test. Presumably since my single run of 12 AWG speaker wire is heating up some much due to the extra power. I also did a few test runs at lower volume so the coils were warmer as well.
I really need a much more powerful power supply for this test. Pretty well simulates a stock Honda alternator or something, though!
- Jacob Fuller
#66
EmperorJJ1
EmperorJJ1
    RE XXX
  • Members
  • 736 posts
  • Gender:Male
nice read...
J. J
Posted Image
My Cardomain
FIRST DUAL ALTERNATOR COBALT SS/SC Posted Image
#67
twink
twink
    Newbie
  • New Members
  • 21 posts
is it okay to use a 350a anl fuse for a 3000d? or 250a fuse?
#68
sundownz
sundownz
    SSA Elite Level 2
  • Vendors
  • 7,927 posts
  • Gender:Male
At 1 ohm you probably would not blow a 250-amp fuse on music. I wouldn't use a 350 as that wouldn't adequately protect the power wire.
- Jacob Fuller
#69
SKEEMASK
SKEEMASK
    Member
  • Members
  • 172 posts
Thanks to Sean we did some power testing on the SAZ-3000D yesterday. Power testing was done on two RE MT 15" woofers, dual 1 ohm coils (0.7 ohm DCR) with a rise to around 0.87 ohms at our test frequency.
Power Output at Maximum Volume before Protection:
67.4 volts
77.1 amps
5196 watts
Power supply voltage was 16.5 volts at rest dropping to around 14.5 volts.
Our clamp meter ran out of steam at 400 amps so we measured efficiency at lower levels:
3294 watts @ 84% efficiency (252 amps draw)
3938 watts @ 81% efficiency (316 amps draw)
4424 watts @ 74% efficiency (392 amps draw)
We didn't have an electrical setup to run 12.8 volt testing available at this time.
So say I wanted to run 2 of these really bad but I had 2 dual 1ohm subs meaning I wanted to strap them @ 1ohm daily (music). Could it be done with a 250amp alt, a Deka Intimidator 9A78DT up front, 3-Deka Intimidator 9A31s near the amps and 2 runs of 2/0? Plus with that much current draw...would the 300amp anl support that 392 amp draw ur showing?
Edited by SKEEMASK, 19 July 2008 - 01:48 AM.
97' Thunderbird
4* 0.75" Kenwoold silk dome tweets
4* 4" Dayton midranges
4* Mach5 MLI-65 (6.5" midbass)
2* Loaded Fi BTL 12s 3mag versions (dual 1ohm)
a Pete Kulicki blowthrough (4th Order Compressed Chambered Reflex) design and build
1* Atomic AT-5000.1D
1* AudioControl DQXS (Active 3way front staging)
1* Phoenix Gold Ryval V754 (4ch amp)
1* Rockford Power T3002 (2ch amp)
1* MechMan 250amp alt ..........TEAM MechMan
1* Deka Intimidator 9A78DT (starter battery)
3* Deka Intimidator 9A31s (rear batteries)
2* 1/0 Knukonceptz runs
Kenwood eXcelon KVT-817DVD (active usb)
#70
Derrick824
Derrick824
    Regular Member
  • Members
  • 532 posts
That current draw is per amplifier. That setup can easily pull 800a+ of current. Four 1500s @ 1ohm each will be much easier on your electrical setup.
Sundown Audio Sales Rep
email - [email protected]
<img src="http://i18.photobuck...sissundown.jpg" border="0" class="linked-sig-image" />
#71
loudcav
loudcav
    Regular Member
  • Members
  • 830 posts
67.4 volts
77.1 amps
5196 watts
ya a fuse can allow mo0re than what its rated for then theres the option thats not supported by warrenty of not running a fuse
Team Sundown
Sundown Audio Ohio sales rep
Im outa here like a heard of turtles
#72
EmperorJJ1
EmperorJJ1
    RE XXX
  • Members
  • 736 posts
  • Gender:Male
what fuse rating does the amp ask for? I have fosgate 2/0 and about a foot inbetween the amp and battery SO im def fusing for the amp not the wire
J. J
Posted Image
My Cardomain
#73
loudcav
loudcav
    Regular Member
  • Members
  • 830 posts
the amp requires a 300 amp fuse
Team Sundown
#74
peter augustijnen
peter augustijnen
    Newbie
  • New Members
  • 2 posts
i am looking for some amps for next year
i have read somewhere in these pages that the amps cant go above 16.5v , can they be modified to run at 18v?
i already have my batterybank
edit; i cant seem to find it anymore where i have read it
but the question stays the same , can they play at 18v
Edited by peter augustijnen, 19 July 2008 - 04:27 PM.
#75
ford302redneck
ford302redneck
    SSA Regular
  • SSA Regular
  • 2,752 posts
Yes, They can play 18volts out the box.
Posted Image
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
#1 Car Audio Forum Since 2001!
