PRE-SALE ORDERS ARE FINAL - THERE WILL BE NO REFUNDS -- If you are not 100% sure you will be financially stable then don't pre-order. No more exceptions.
These amps are capable of a real 1500+ watts at 12.8 volts. They will out-perform many other 1500 watt rated amps (like the Audiopipe 1500) easily!
COST ON PRE-SALE :
AUGUST - $250 each
SEPTEMBER - $260 each
OCTOBER - $270 each
NOVEMBER - $280 each
PRICE IS SHIPPED IN CONTINENTAL 48 STATES. CONTACT ME ABOUT AK, HI, and international !!!
The earlier you pre-order the lower the price will be.
REGULAR price will be $350 MAP / $549 MSRP when in stock!
PAYPAL me at [email protected] to take advantage of the pre-sale offer.
Pre-sale will be closed on November 15th !
Externally it will look just like the old model SAE-1200D :
Specs are also rated the same :
SPECIFICATIONS:
* 1200 x 1 watts @ 1 ohm
* 600 x 1 watts @ 2 ohms
* 300 x 1 watts @ 4 ohms
* 0.153v - 5.6v adjustable input sensitivity
* 15 Hz - 250 Hz Frequency Response
* > 90 dB S/N Ratio
* 4-Way Protection Circuit (Thermal, Overload, Speaker Short, and Over Current)
* 50 Hz - 250 Hz adjustable 12dB Low-Pass Crossover
* 15 Hz - 50 Hz adjustable 12dB Subsonic Filter
* 0 or 180 degree adjustable phase switch
* 0 - 12 dB adjustable bass boost with 60 Hz center frequency
* Wired Remote Control unit included
* 5x 30 Amp Internal Fuses
* 17" L x 10.6" W x 2.2" H
BUT the board is ALL NEW in design :
Updates :
1) Double sided PCB board (v.1 was single sided)
2) More primary input caps
3) Large brass bars for power supply current
4) Revised layout
5) Superior Soldering and assembly quality
TESTING vs. similar board to Audiopipe 1500 / 1800 :
  • Replies 115
  • Views 24.3k
  • Thanks bigrank916 I will be sending the money shortly. I had the first one, it was a great amp. I recently got all my amps/cd player/dash/cd's stolen so I am lucky that there is a pre sale.
Woot! Awesome deal. Just curious though, does it have 0 ga or 4 ga terminals? $250 for 1500 watts!? :pornsmilie:
For a daily ground pounder would you recomed the saz1000d over this amp. The saz1000d is a little hiegher quality. How well will this cool
Take a look at the heat-sink -- it stays quite cool as we added the internal fins to this model case as well.
1/0 power terminals and it needs them... it's powerful.
Thankyou. So when I paypal you all I need to is send you the 250 is there any other imformation you need other that shiping adress which paypal should provide.
uh, i, uh well no, no wait, my friend, yeah, a friend of mine said how does this work....pre-sale? do you get amp now or do you have to wait? sorry he is a complete noob !
Man what are you trying to do to me? No I dont need it. But yes I really want it! 1/0 gauge terminals with 1500 watts?! I guess they are a little power hungry eh? :fing34:
You pay for the amp now and you dont get it till the Presale is over usually when Jacob gets them in his hands. Its just a way to reserve you an amp (pay a great low price) and get one right away so in case their all sold out, you got one.
Expect a preorder from me tomorrow! fing05.gif:wacky::drink40:
so I can't use 4ga wire or is it just not recommended? I would rather not have to rip apart my wiring if i didn't have to.
4 gauage is too small if you plan to get full power from this amp or any other amp capable of 1500 RMS, IMO.
  • 2 weeks later...
I am interested in this pre sale. What is the difference between this amp and the SAZ-1500D? Which amp will require more power from the vehicle's electrical system?
At 1 ohm on a 12v system with only one amp... performance is on par with the SAZ-1500D and maximum current draw is similar.
With the SAZ-1500D you gain the ability to run 18v, strap amps, and run under 1 ohm for competitions.
End of November is the ETA (estimated time of arrival).
ok looking to preorder oh wait no planning to preorder but need to make things clear first so with 0ga wire from batt to amp off a 12v system it will push 1500rms? Plan to preorder tomorrow if get an answer and do all i do is put 260 in your palpay account and put 12000d preorder getting all worked up just thinking about it but wish it came sooner fing05.gif
If only my car had a bigger alternator I would have one!!!!!!!!!!!!!!!
