Box size has alot to do with mechanical power handling. If you are going to be pushing your woofer beyond it's rated RMS power you need to be very mindful of this fact and put the woofer in no larger than the minimum suggested enclosure for music program. We design our woofers for very small enclosures and power ratings are there for a reason -- you can continue to push a driver like the SA-8 beyond RMS power and it will not be stressed whatsoever thermally by the time you can cause mechanical i
