RAM_Designs
674 -
Days Won
2
Posts posted by RAM_Designs
Is it safe to ask if two of these would outperform 2 XS D3100's? Even thought it does seem like an apples to oranges type deal...
If you want to try and pull a crap ton of power at once, like for burps, the XS will likely do better. These are better for sustained power delivery where you can run multiples to reduce the amperage draw on each battery, like for demos. That's really where they would excell.
0 -
Also, price is now $699 + freight
0 -
Minimum order is 4, sorry. Maybe get a group buy together with some locals?
0 -
Local guy needed some of these, but he's always out of town....so we just had them shipped to me instead so he can come by and get them at his convenience. Here they are all packaged up and ready for shipment, 13 of them.
0 -
Price drop to $699 plus ship. Shoot me an email if ready to buy.
0 -
Please contact me at Ryan@RAM-Designs.com if you're serious about buying. Or message me on facebook if we're friends (or even if we're not).
Shipping quotes for 4 of these are right in the $150-200 neighborhood, so people are getting total quotes under $1000 for these never used monster batteries shipped to their door. 760ah of new batteries for under $1000 shipped to their door...hard to beat that deal right there.
Also, please only ask for exact shipping quotes if you are seriously interested in ordering. I do not want to have to bother this guy all the time with quotes if you do not have a very serious interest in getting in on this deal. And as always, the more you order the cheaper price it'll be per battery.
Item(s) for Sale:
190ah agm batteries.
Item(s) Description/Condition:
Four(4) for $799 + shipping via freight services! Need a big order? Get a group buy together with some friends and I'll be able to offer a better rate!
I have come across a very large quantity of massive 130lb AGM batteries made by EnersSys, same company that makes DataSafe...They're known for their quick discharge rate. I am basically helping this company move these, and figured I would offer them to the basshead community.
These are a year old but are brand new and never used. They are rated at 190ah, weigh nearly 130lbs, and have top mounted terminals to easily attach your wire leads via bolts. They're pretty skinny so you can mount several of these side by side in the back of a SUV or van. They're a hair under 5" wide, so you can fit 9-10 of these in a large SUV for some serious battery backup.
Only catch, minimum order is four at $799 + freight charges, which is a great deal for some never used monster batts. If you're in DFW I can pick them up and meet you for $850 even (to cover travel costs), $500 payment must be made ahead of time so I know you're serious and not wasting my time...rest to be completed when you get the batteries.
Specs here: OSI Batteries - EnerSys PowerSafe 12V190F Battery 12V 190Ah Front Terminal
Price:
$799 + freight shipping
Shipping and Miscellaneous Item Information:
$150-200 depending on location
Item Pictures:0 -
Yeah, he got a surprise for sure.
0 -
This is a vid that got sent to me by Randy Strickland, who got a design done for a pair of AudioQue HDC12's to go into his Civic hatchback. Final specs are 2.25ft^3 per side with a common 36hz port. I did what I could to edit it a little and make it somewhat creative...enjoy!
0 -
Is this installed and playing yet?
Not yet, it'll take a few weeks for the build to be done.
0 -
Here we have a ported wall for four DC Audio Level 4 XL 18" woofers. The final specs are 22.5ft^3 with a 33hz tuning. As you can see, we had to get a little creative with the port to get a reasonable amount of port area, but it came out looking pretty cool in the end. The entire box is double layered, with the baffle triple layered.
0 -
Thanks Supra, I'm trying to get more active again...just been crazy busy for the past few months.
0 -
Thanks guys.
0 -
21.25ft^3 for a quad 18" box design housing some custom Ascendant Audio Mayhem woofers, using some custom 18" TC Sounds baskets. Final tuning is at 35hz, and this will be going in a Suburban.
0 -
again
0 -
bump, 16 sold.
0 -
to the top
0 -
to the top
0 -
bump
0 -
bump it
0 -
Email me at Ryan@RAM-Designs.com if interested....I do not respond to PM's, and may take a while to respond to posts. Email is definitely the best way to get a hold of me.
Item(s) for Sale:
Sony 5.25" shielded neo mids.
Brand new, never used or mounted.
This Sony neodymium woofer features an attractive, high quality treated paper cone, high-excursion flat spider, and extended pole piece for improved bass response. It is recommended for use in surround speakers, mini monitors, or compact multi-way systems, as well as being an ideal candidate for line array designs. Magnetically shielded.
*Power handling: 20 watts RMS/40 watts max
*VCdia: 1"
*Le: 1.52 mH
*Impedance: 8 ohms
*Re: 7.71 ohms
*Frequency response: 80-6,000 Hz
*Fs: 81 Hz
*SPL: 85.3 dB 1W/1m
*Vas: 0.16 cu. ft.
*Qms: 7.81
*Qes: 1.10
*Qts: 0.96
*Xmax: 3 mm
*Dimensions: Outside Diameter: 6-7/16", 5-1/4" across flats, Cutout Diameter: 4-7/8", Depth: 2-1/2".
Price:
8 for $40 shipped, will only sell in multiples of 8.
Included in price.
Item Pictures:
0 -
Email at Ryan@RAM-Designs.com to order with your measurements ready please. I DO NOT RESPOND TO PM'S.
Item(s) for Sale:
1/0 Big 3 kits using black Audio Technix CCA and OFC wire. FIRST 10 ORDERS GET A FREE AUDIO TECHNIX DECAL!
These will be made using Audio Technix CCA and OFC wiring, which is some stout wire for 1/0...barely fits inside the 2/0 ring terminals I am using. The ring terminal bolt hole can fit a 3/8" bolt. The connections will be crimped via a hydraulic crimper to ensure that the wire will never come loose. The connections are then heat shrank with adhesive-lined heat shrink tubing that will not budge once shrank. All in all, it makes them look very clean, and the black on black look keeps it stock looking as well.
Price:
$49 shipped for CCA
$69 shipped for OFC
Included in price.
Item Pictures:
0 -
I cannot keep track of all the forums I am on, so please email me at Ryan@RAM-Designs.com with your PayPal address so I can send a PayPal request to you.
Item(s) for Sale:
(10) 2/0 ring terminals
-tin plated to resist corrosion
-fits 2/0 welding wire or over-sized 1/0 CA wire
-3/8" bolt hole
-access hole in front to feed solder into for a superior connection strength
Price:
10 = $15 shipped
20 = $25 shipped
30 = $35 shipped
etc.
Included in price.
Item Pictures:
0
4 New 130lb Batts for <$1k
in For Sale/Wanted
