DanP
Members
    466
  • Days Won
    1
Everything posted by DanP
  1. Is this an AGM Battery or an acid battery?
  2. DanP
    Help with new build? 1800 usd budget.
    ebay for the alternator. not sure on the company but it charges at 1200rpm so it seemed good to me. I can double check on the brand. "***Full output of 250 Amps is achieved at over 1200 engine rpm.***" be careful they say over 1200 RPM Which could mean 5k RPM Realistically..
  3. DanP
    What company are you using for the alternator? and have you considered buying used gear? There's a lot of used gear on the net for pretty good prices.
  4. DanP
    My First "Real" Jeep Build
    Mounted my amps today, should be building my sealed enclosure tomorrow, wanna stop at a fabric place and find something to wrap my amp rack in.
  5. DanP
    quick install question
    Or get some toolmaker terminals
  6. Im building a sealed enclosure for my 2 15" Obsidians that's gonna be about 4 Cu Ft. after displacement. I plan on using my Hifonics Zeus 2000 which has a subsonic filter on it which for my ported enclosure I set about 5 Hz under my Box tuning. There's no option to turn the Subsonic filter off so I'm wondering what exactly I should set it at when using it for a sealed enclosure. Sorry if this lacks detail I'm unsure how/what to base setting it off of so I'm not sure what else to include.
  7. DanP
    brought home some wood - the plans...
    My Jeep doesn't like wood strapped to the roof like that.
  8. Yeah I imagined that but since my subsonic filter doesn't have an option to turn it off, would I just turn it to the lowest setting?
  9. DanP
    Decided I wanted a doubledin touchscreen, Jeeps comes stock with 1.5 Dins so it required some cutting. I gotta sand the panel down some more, then do some fiber glassing. I'm not shooting for perfection but I wont settle for how it looks now.
  10. DanP
    Its been raining a lot in NY Lately and I work at festivals that mainly have grass parking so I've been seeing a lot of vehicles getting stuck lately. Jeeps come with absolutely 0 Tow points so I decided to throw a hitch on. Also went half and half on that popup camper with my dad, have to do a few repairs to the canvas before its ready to be used though.
  11. Adding a 3rd layer if I'm not mistaken would only change the displacement of the Sub, which would be a minimal difference for tuning.
  12. Could zip tie them together to reduce vibration a bit, in the sense of them rubbing against each other.
  13. DanP
    WTB> 2 10" Subwoofers
    Messaged Tirefryr
  14. DanP
    Not many goals honestly just adding some bump to my Jeep I'm selling my Obsidian 15's so just looking to downsize space wise.
  15. DanP
    10s are preferred but I'm open to anything.
  16. DanP
    Crescendo Mezzo Components
    you always post stuff as soon as I'm broke =/ GLWS
  17. DanP
    EVIL Tahoe | Mark's SSA DEMO MACHINE **new pics p8**
    When is that? Where? I would love to come down for that schedule permitting... Its August 25th in Brewerton, NY
  18. DanP
    Welp my box has a new owner meeting up with him on Friday, and I'm still trying to find a buyer for the OAs. Once this box is gone im gonna try my luck with fiberglass and see if I can't make myself a stealth box and work towards more of a SQ System. Ive had my fun with my 15s but since this Jeep is my daily driver they just aren't convenient especially when I need to use my cargo area. Maybe once im done with college and have a sufficient income I'll have a go at building a "spl" machine.
  19. DanP
    You gonna have this at the TNESPL Finals @ Syracuse Customs?
  20. DanP
    WTT my SSA XCON 18 for a smaller woofer
    Would you consider an obsidian 15" + cash?
  21. DanP
    Lights flicker.
    But my voltage at the amp never drops below 13.4. Neither did mine I assumed it had something to do with my Jeeps PCM
  22. DanP
    Lights flicker.
    I have a Singer 270Amp alt in my Jeep with a DieHard G34M, When I had my 2K I wasnt getting massive voltage drop but my lights were dimming as well. I added a little Kinetic600 to the back and it went away.
  23. DanP
    Lights flicker.
    What do you have for batteries?
  24. DanP
    mdf
    You might want to use a more reliable calculator then RE Box calculator.
  25. DanP
    Thats what I initially though because the keys for the Jeep have Chips and you need to bypass for remote start but nothing on the wire was exposed, and id imagine the wire would have to touch the metal? Regardless im ordering one of those alarms with an LCD on the remote that goes off when a doors open and shows which door, so Ill just save that project until I purchase that. I actually had to do this last week at a shop i work at. I used the secondary key to make sure the chip was a ignition issue. But in short the reason your probably has that key behind the dash is because the chip in the original key failed. And alot of people will do that instead of changing the ignition cylinder. It can be done on chryslers chevys and any car with a chipped key. What happens is that your sort of bypassing your anti theft system, the wires should be going to the key cylinder and then when wrapped around the other key(and then some wires have to be cut and jumped), it will fool your car into thinking it has a the correct key in it. This doesnt however make your car easier to steal. from what i understand you should still have to have the chip in the original key to make the complete circuit to start the car. Before I removed the key my Jeep would only start with the chipped key, and it would stall out with an unchipped key, and since I removed that key its the same way so im unsure of the actual reasoning.
