ParrishElectronics
Members
    142
Everything posted by ParrishElectronics
  1. ParrishElectronics
    Passenger Side Tweeter Mount 2
    From the album: 1995 Cadillac Eldorado
    Passenger Side Tweeter Mount - Beginning Stages
  2. ParrishElectronics
  3. ParrishElectronics
    Fun pics Sundown SD-2 8s :)
    Good lord those things are crazy. I wonder how far some of these manufacturers are going to take things?
  4. ParrishElectronics
    new B2 build. 09 silvy crewcab.
    Nice looking equipment, first time I've heard of it though. Have you used it before? Certainly interested to hear your thoughts on it.
  5. ParrishElectronics
    New Build - 1995 Cadillac Eldorado
    I know everyone likes to see subs, so here are the four 8" Blues drivers that I will be using in this build. I just have to get the materials to put the Iso-kits together.
  6. ParrishElectronics
    Blues 8" Drivers - To be used in 2 Iso-kits
  7. ParrishElectronics
    Sorry for the lack of updates recently. Weather here has not been too friendly over the last few days and when I work, it has to be outside, no garage. Hoping to get back on it in the next few days.
  8. ParrishElectronics
    KE Ported Enclosures HD Photos
    Nice looking enclosures. The internal bracing is not something you get everywhere with pre-built enclosures. Well done.
  9. ParrishElectronics
    help me choose a sub
    I listen to rap and r&bI think a ported enclosure is the way to go. I use Blues speakers and Linear Power amps exclusively. They are the best in the business in my opinion. However, they fall outside of your budget. That being said, I did a little looking around. Seems like a couple of 10 in. subs from SSA or Sundown would be a consideration. I looked at the mounting depth and enclosure recommendations and you should be good. 12's from either company may not fit with your size requirements. As far as an amp goes, for your budget, I would perhaps take a look at something from Zed Audio. Steve Mantz has been designing and manufacturing amps for a long time. His new stuff gets great reviews even though I have no personal experience with it. I used some of his old stuff back in the day and they were very good quality. Hope I've been able to help a little. I will certainly try to continue to help if you need it. Best of Luck.
  10. ParrishElectronics
    What kind of music do you mainly listen to? If loudest is your goal, I would take a look at a ported enclosure, find a sub that will perform well in a ported enclosure, and tune it to the proper frequency. You should be able to get a pretty good amp for that amount of money. Just don't cut corners when it comes to the enclosure, wiring, etc. You may want to take a look at some of the SSA subs. They have several different types and are made here in the US.
  11. ParrishElectronics
    Need help with cross over frequencys
    I'm not exactly sure I understand your question. However, I will try to offer what assistance I can. Just about any head unit will clip if you turn it all the way to the max. Just don't do it. You should set your gain on your amps properly. You will need a test disc with pink noise on it, and a multi-meter. There are many articles out there on how to do it. I'm not going to get into it in this post, just do a search and you will find it. As far as crossovers go, does your head unit have it built in? It sounds like it from your description, but I just want to be certain. If so, use your owners manual and follow the directions on how to get to it and how to set it. As far as WHAT it should be set to, you should check the specs on your speakers. Check out their frequency response. I'm not saying that's where you should set it, but it's a good starting point. If you have any more specific questions, please just ask and I will do everything I can to assist.
  12. ParrishElectronics
    2010 Malibu SQish
    Nice work so far, great pictures.
  13. ParrishElectronics
    a memeber has questions....
    I just don't understand the need of people to make fun of or talk negatively about others. This forum is for members to share their audio builds, ask for advice, bounce ideas off of others who have the same interests. There's no reason for personal attacks. I just don't get it.
  14. ParrishElectronics
    There are many good subs on the market. I believe its more to do with personal preference than anything else. However, what would you like to hear from this sub? Plays low? Loud? Ported? Sealed? And, even more importantly, how much do you want to spend on an amp when it comes time to purchase one? I would certainly try to make sure that whatever sub I chose, I was able to properly and cleanly power it. From the looks of your measurements, your choices may be limited by mounting depth. Make sure to take a look at this spec when shopping for a sub. Sorry, I know I haven't suggested any particular brand. I just think that enclosure size, type, power, etc. is much more important than the actual sub. Hope this helps a little. Best of Luck.
  15. ParrishElectronics
    HO Alt on single batt
    Agreed. Can't stress enough the importance of upgrading the factory wiring. This is true anytime installing an aftermarket system, IMO, but especially when upgrading to a high output alternator. 300A is a LOT of current and the wire needs to be capable of delivering it. Best of Luck.
  16. I will absolutely 2nd this post. Spot on. The use of foam to stop rattles and unwanted noise in a vehicle is very underrated by most. Please don't over look it.
  17. ParrishElectronics
    Cablguy184's 97 Chevy Silverado
    I'm definitely looking forward to hearing this again with the 6.5 in the door playing. Those 5.25s are unreal, but I'm sure the little extra in the door makes a nice difference. I wish you much luck working with the insurance to get the hail damaged resolved. I know it's probably a pain.
  18. ParrishElectronics
    Mazda 6 - Team Fi - 2 15s - 20,000 watts
    Good luck with the build. Definitely looks like a lot of work and it makes my ears hurt just thinking about it.
  19. ParrishElectronics
    Do you know a good speaker kill switch?
    I still don't understand the problem with this. As long as it's not being switched with any real power on it there shouldn't be an issue. I used to have a test rig for installing speakers/components/etc. that had six double pole/double throw and four double pole/single throw non-shorting switches mounted in a box with long pigtails in it that allowed me to connect it between the amp/speakers or crossover/speakers to do instant phase reversing on individual drivers. Never had any issues doing that, though I did use high quality switches and would turn it down before making the switch anyway. Made an instant and easy way to test phase relationships in a car. As I state, it can be done. I usually just don't recommend it to anyone because of the chance of making a mistake. Constant 12v, remote power, etc. usually (always should) have a fuse inline. If something shorts to ground you have a fuse to bail you out. This is not the case on speaker wires. If the amp were under power and somehow the switch was accidently hooked up wrong, or the exposed prongs were not properly protected and it shorted, depending on internal fusing of the amp, you could cost yourself a lot of money. If you are careful, it certainly can be done. I just don't recommend it because of the possiblity of damaging something.
  20. ParrishElectronics
    Why I am still dipping?
    As stated, check all connections including power and especially grounds. I always sand off paint and primer and use bolt, star washers, lock washer, and nut through the FRAME, when at all possible. I also then apply some type of protectant over the connection to prevent corrosion and/or rust. If all connections are very good and you still have the issue, I would then look at the possibility of a 2nd battery. If you have a multi-meter, check the voltage at the terminal on the amp with the music playing and see what kind of a voltage drop you are looking at. I would do this both BEFORE and AFTER I did anything to the connections to see if I had made a difference. Good Luck.
  21. ParrishElectronics
    I certainly understand you point OP. I know I don't have to tell you this, but do what you like. It may be good, it may be bad, but no one has ever evolved by doing the same ole. There have been many great ideas come about from someone trying something off the wall or just different. As previously stated, you should be able to locate a switch like you are looking for from any parts house, Autozonoe, Advance, NAPA, etc. They usually have a pretty good selection and I'm betting you can probably find one in blue. Also, as someone previously stated, I don't think I would put a switch on the speaker wire itself. If you have the option, I would put it in the circuit with the remote wire for that particular amp and just turn off the amp. Even though it will work on the speaker wire, its just something I don't consider a good practice. Best of luck on your project.
  22. ParrishElectronics
    08 Ford Edge. First build log.
    Nice install. I really like the detail and pictures you give. Just a thought, I've always put some kind of protection on my power wire anytime I have had to run it outside the vehicle. Sure, it may not be necessary, but its for my peace of mind. In the past I've used a clear PVC type material that was just a little larger than the outside diameter of the wire. I run the power wire through it and then installed it. Turned out pretty nice. I've also used flex loom, but to me its not as good as the other. I feel your pain on the screwdriver bit through the woofer surround. I've done that twice in my life of installing. I've sworn no more. I now put my enitre hand around the bit and screw. I figure if it slips off it will damage my hand, not the woofer. My hand will heal. Keep up the nice work.
  23. ParrishElectronics
    Looking for a Replacement
    Dang, I should have waited I though I was the only one that kind of thing happened to.
  24. ParrishElectronics
    Hey man, thanks. Yeah, working on it, just slow go. I'm going to try and make one of those upcoming shows, Lebanon, TN or Florence, AL. Hopefully will see you there!
  25. ParrishElectronics
    Thank you much.
