391 -
Days Won
1
Posts posted by Dexter Chaos
I am looking to buy some horn drivers from eric stevens just not sure how or where to order them. looking for some help
0 -
sold
0 -
Pm responded to
0 -
Pm responded to
0 -
New price $105 included 2 faceplates one brand new and 2 remotes one braNd new
0 -
bought these in may of 2014 going a new route.
PRV-Audio 8MR500-NDY-4 8 inch. Single Midrange Speaker, Neo, 500 Watts
Power handling: 250 watts RMS/500 watts peak
Details: The PRV Audio Pro Audio Loudspeaker, 8MR500-NDY-4 midrange woofer offers outstanding durability and a smooth midrange response through 8.5kHz. This woofer is perfect for home Hi-Fi installs, including bookshelf, satellite, surround sound speakers and even the home studio monitors. It is a great option for three way cabinets requiring additional midrange support. The high end neodymium magnet assembly was chosen to increase sensitivity and power handling. This neodymium is attached to a sturdy reinforced cast aluminum frame to ensure a solid support structure for long lasting play in most any environment. Its light weight of only 1.05 lbs helps keep your enclosures light and is a great use for use for car doors and installers looking for high SPL midrange and upper midrange responses
Voice Coil Size: 1.5"
Impedance: 4 ohms
Frequency response: 100-8,500 Hz
SPL: 98 dB 1W/1m
Qms: 15.36
Qes: .902
Qts: .852
Xmax: 2 mm
Dimensions: Outside diameter: 8.1" (206.3mm), Cutout diameter: 7.3" (185.6mm), Depth: 3.1" (80.3mm) 2.33lbsasking $125
0 -
this vape juice still available?
0 -
from what I have read some have more power requirments that a single usb will supple. some recommended a usb y. Really appreciate the test though. thanks.
0 -
appreciate it
0 -
http://www.amazon.com/gp/product/B005J7YCHG/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
I was looking at one of these 500gig to 1tb gig. wasn't sure if the size will change its ability to work.
0 -
So I am tired of having multiple thumb drives and wanted to used and external hard drive. before I go buy one and download a bunch of music will this work?
0 -
these are sold.
0 -
I am looking for a zed Draconia II to match my other amp. Looking a lead on a used one is prefered. Let me know what you got.
Thanks
0 -
Hell yeah
0 -
200 for the broken
0 -
thanks aaron
0 -
Oh then I would do 5 net maybe 5.5 with around the same port area tuned 32-34hz. But there may be better opinions out there.
Thanks lee I am looking for opinions/help. all advise will be thought through
0 -
box has already been removed. plus one sub needs recone. that is why box was removed. thanks lee
0 -
I have been running 2 12" zcons for little over a year. 6 cubes 38hz 80cuin of port area. drivers side port all facing into cabin spray foam sealed of family car. trunk build. still have to load kids in back seat. seats fold down.
Always been run at 1 ohm.
I was using a saz3500v1. when I built that box and tuned it.
I recently bought a B2 M1s to run on these subs. 7500w @ 1ohm.
with the power increase I was looking for any help with what the new box would require as far as net volume. Looking for help????? suggestions???
0 -
Which one?
0 -
you just installed these?
0 -
How's it sounding with the new enclosure. Pics and mid and highs amp I personally don't think you can go wrong with the ppi900.4 or the 600.2. Great power, small footprint.
1
HLCD drivers where to buy?
in SPL & SQ / Fabrication
so the pro vs. the comp version. any real world information about them. I'm sure there is difference I will notice.
