MP3
40 -
Posts posted by MP3
How would the IXL sound in a 3 ft^3 tuned to 35 hz?
0 -
How do you wire it to a 1 ohm load?
0 -
I listen to rap so I guess that might be a good tuning
0 -
how big is the cutout for the ixl 15? I can't find it anywhere
0 -
Is tuning a ported box to 35 hz for daily use normal.
0 -
Which box would be best suited for daily use for the IXL 15? Or if anyone could help make a box.
http://img23.imageshack.us/my.php?image=3c...hz56sqin6nx.png
http://img23.imageshack.us/my.php?image=3c...z465sqin4wj.png
0 -
How do they compare to mach 5 ixl's? I have been watching some vids of the ssa and they are impressing me more.
0 -
are the Icon series more spl setup? When are they coming back in stock? Which of the sundown amps would work better on a 15 the 1500 or 1000?
0 -
I live in Ohio and I dont think there are any dealers around here so where can I purchase a sub?
0 -
Which amp would work better with a Mach 5 Audio IXL 15, The sundown saz 1500d or the sae 1000d?
0 -
Which of the sundown amps would you suggest the sae 1000D or the saz 1500D?
0 -
What would be a good size ported box and a tuning hertz?
0 -
Whats the difference between the audioque AQ1200D and the Sundown Sae 1000D? What would needed in the electrical to properly run both?
0 -
but it can still get pretty loud just not as loud as the HDC315?
0 -
How does the IXL compare to the audioque HDC315?
0 -
Is there any amps around $300 that would work well with this sub. How are the audioque amps
0 -
Im guessing with these amps I should look into a h.o. alt?
0 -
Id probably go with a ported box. Any suggestion for an amp.
0 -
the biggest sub i can fit is a 15
0 -
I would only get one 15. Id use it for daily use. would this be a good choice if I just listen to rap. I was watching videos of the maw 15s and they seemed to get loud
0 -
are the ixl 15s more of a spl sub? Whats a good amp to power it?
0 -
Im not sure if it helps but I just installed a new yellow top battery. Would getting my alternator respun at a shop for more amps work? I normally never sit there and listen to music at idle and I normally always turn it down at stop lights for attention reasons. Would there be an amp youd suggest for the Mach 5 sub?
0 -
What would you say I would need to do to this car to be able to power that sub. If I got the mach 5 sub would I need to upgrade anything?
0 -
80 amp. Id like to stay away from getting a new alt because I won't have this car much longer.
0
Wiring 15" IXL
in Subwoofers / Speakers
How do you wire a 15" IXL to a 1 ohm load? neg-neg- neg on amp and pos-pos- pos on amp?
