cobracommander
Members
    110
Everything posted by cobracommander
  1. cobracommander
    82 Oldsmobile Cutlass Build log
    great idea posting on the internet where you put the alarm
  2. cobracommander
    mli 65 crossover?
    the mli65 can be run full range but imo I would runs an active setup with a 4ch amp and a crossover
  3. cobracommander
    diferance of the mj18 and the mj18m?
    I wouldnt, really they are 2 different subs, the M is upgraded but I wouldnt.
  4. cobracommander
    what battery?
    Deka batts are the poop! You could put a 9a78dt up front and a 9a31 in the back. That should work. Who makes your alt? You say 200amp but you know thats like 80-100 at idle right? Plus depending on your compressor it alone could draw like 40 amps constant by itself. I know you wanna save $ but you just cant skimp or you will burn chit up. edit- sorry just seen you dont have bags, but yea you are gonna have to have 2 batts, atleast another 9a34m in the back, even then you will probably get voltage drops.
  5. cobracommander
    what battery?
    probably goodbye to you amp first from low voltage. I doubt you can fit a g31 under the hood. What car?
  6. cobracommander
    the mj18m has a bit bigger motor and handles a lil more power
  7. cobracommander
    what battery?
    they usaully dont, most likely one wont be enough anyways
  8. cobracommander
    what battery?
    you are probably going to need more than one, 9a78dt or 9a34m up front and a 9a31 in the back
  9. cobracommander
    need advice on buying a home theather system
    building a sub is gonna be the best for your money, with buying speakers and a receiver youw ont have much left. Just abot any name brand receiver is going to be ok.
  10. cobracommander
    i was eyeballin these the other day http://stores.ebay.com/CADENCE-DIRECT_Home...1QQftidZ2QQtZkm for a sub really depends on how much you can spend, i would buy a plate or rack amp from PE and a sub to match then get someone to build you a box if you cant, same with receiver, get the best one you can, used is fine, I got a Yamaha a few years old for like $40. Guess it depends how man hdmi inputs you need and if you want on screen
  11. cobracommander
    wall spots you mean like a place to put a speaker or an actual in wall speaker?
  12. I like Deka. I dont have exp with powermaster but Im not going to be switching from Deka any time soon.
  13. I heard that Auidobahn went out if business. So I would look see about the warranty. No warranty no bye I would say someone bought alphasonik, dont know how they are handling their warranties though
  14. cobracommander
    Which Cap
    because they make good caps
  15. it looks like people like mechman and dc. When I talked to mechman he told me that their 250 amp alt does 150 at idle which is real nice. It doesnt help too much on a street car if you have to rev to 2200 to get 150 amp like most companies. Also my car uses a small case Nippendenso alt which i have seen rewound to 200 amps but still like 80 at idle and decreases the life expectancy because of the small case. So he MACHINES an entirely new larger case that fits the stock bracketry.
  16. cobracommander
    Impounded
    nice truck
  17. those aernt too acurate, atleast get a crafstman, if you are just gonna get cheap the try harborfreight
  18. cobracommander
    Car Club Name
    no problem
  19. cobracommander
    Car Club Name
    x2 it ends up being like a gang. You get young punks actin out and draggin your ass into all the drama. Why do you need a club? Just want a perty sticker on your back window? If you want to hang around people with similar interests you dont need a sticker on your window. Tried that ish out like 10 years ago when I was 18. Total bs.
  20. cobracommander
    mj's
    baby got mo cakes than duncan hines tell me what movies that is from
  21. cobracommander
    Car Club Name
    car clubs are teh gheyz
  22. cobracommander
    BOSS LAC129D
    I would just take a general guess like 1.5-2 cubes each
  23. first I would upgrade the factory alt to batt wire and ground in the engine compartment
  24. cobracommander
    mj's
    dead heads and frog legs, mmm cake mix
