dbEric
13 -
Posts posted by dbEric
I'll post a negative. The paint isn't 100%. I wish I would have used body filler over the entire surface and sanded to get the best possible surface for painting. I would hace also gone with a bedliner time spray on but this is fine if you don't go right up to it under the light.
I also need to put in a port brace since I can almost feel the ouside wall flexing.
Soundstream Amp is nice. I also have the matching C-1 pre-amp and T-1 tuner. The amp is just starting to clip at the maximum I would want to push these. The amp does get real hot when pounding away.
I've been delaying speaker porn and the output mesurements. SOON...
0 -
no it won't. I grabbed the wrong tube of caulk. I used some silicone around the subs and that is clear.
0 -
Taking the subwoofer out from my receiver to a low pass crossover and then to the Soundstream C-1 preamp and onto the Soundstream DA-1 dual monoblock amplifier.
-Soundstream DA-1
Dual monoblock power amplifier
200 watts /channel, 8ohms (continuous power, minimum rms, 20Hz-20kHz, (with less then 0.1% THD)
300 watts/ channel, 4ohms
400 watts bridge, 16ohm
600 watts bridge, 8ohm
Frequency response 20Hz-20kHz +-0.1dB
Bandwidth 2Hz-100kHz
Slew rate greater then 35v/us
Crosstalk greater then -110dB
Signal/Noise, A weighted greater then -110dB
Gain x40, 32dBv
Dynamic Headroom greater then 3dB, 4ohm
Dimensions 5 7/8" x 17" x 14"
Weight 35lbs
-Soundstream C-1 pre-amplifier
Input impedance 30k ohms
Input sensitivity less then 100mv for 0.5Vout
Maximum input signal 10Volts
Frequency Response 20Hz-20kHz +-0.1dB
THD less than 0.05%
Signal/noise, A-weighter greater then -110dB
Crosstalk greater then -100dB
Maximum Gain 15dB
Headphone ouput Impedance 30 ohms
Main Output Impedance 1000 ohms
Minimum Recommended load 5000 ohms
Maximum Output Level 10 volts
Treble +-8dB, 10kHz
Bass +-10dB, 50Hz
High Cut Filter 8kHz, 6dB/octave
Mute -20dB
Dimensions 3 3/5" x 17" x 11 1/2"
Weight 15lbs
Elemental Designs 12Kx.2?2
-12" dual voice coil subwoofer
-150/400 power requirement
-Dual 2 ohm coils
Qts: 0.30
Qes : 0.34
Qms : 3.16
Vas : 181.65L
Sd : 545.42 cm^2
Xmag : 12.5mm
Xsus: 18.9mm
Xmax: 12.5mm
MMd: 178g
Re: 2.39
Fs: 17Hz
Bl: 21
6 cube box tuned to roughly 21-23Hz. Hooked up 4 ohms per sub.
My secret glue
It replaces this
0 -
Very nice to hear
0 -
Just to set this straight, I am all for oyu and Zed Audio. I just kept reading these horrible threads that were just bashing on you and the minilith and wanted to hear the real story or get an actual copy of the letter you sent out.
People made it sound like there were a bunch of miniliths which had trouble with 1ohm loads, now you say there were 2 cases well now that makes a bit more sence. This thread is old....all I wanted, like others, was an explanation from you.
When you say there were 2 cases and not a hand full then I beleive the story of DCR resistance being too long on certain subwoofers. So I apologize if I seemed hasty with some comments.
0 -
6.0 Mbps download and 800 Kbps upload is $50 including modem rental.
We are VIP members so we get liek 15% and something off. So really we pay like $39-40 for a 3Mbps. I perosnaly prefer Bell Sympatico and they cost same but isn't available in my area. But 1km it is. It's weird. We have TV cable, digital cable, internet cable and mobile phones with Cable so it's worth staying with them.
0 -
Rogers digital cable 3Mb/s download, 384kb/s upload
$44cnd a month 60GB bandwidth limit.
Bell sympatico high speed phone is faster int his area. You can download at 300-350 without a monthly bandwidth limit.
Your download speed : 1966734 bps, or 1920 kbps.
A 240 KB/sec transfer rate.
Your upload speed : 418235 bps, or 408 kbps.
0 -
I don't buy this voicecoil crap unless you have a defect and the subs read like 0.5ohms instead of 1 ohm. But even then, a 1ohm stable amp should do fine with a 0.7-1.0ohm rating on music.
Stephen, please clear this up. I am only hearing from people that don't know anything about the situation. If it's a production hickup, then state it as that....better then having all this chit go around on the net.
0 -
That amp is tiny!!! I would love to see some internals of these amps.....give me the god stuff!
0 -
DCR means squat. There is one hell of a thread brewing about this over on Soundillusions.net
I would also like to hear the real story.
They are saying, why the hell is the amp rated for 1 ohm is it isn't stable. No one posted the letter you sent out so I didn't want to get involved. But I would surely like to get the truth behind this story and set it straight over there.
0 -
Hey, sorry I didn't respond any quicker. I've been out of town for a week.
Yes it's dB. I guess I typed it wrong or I just don't care!
I don't even have time for another forum so I don't know how I am going to manage this one.
Just a little info. I'm from Ottawa Canada. I haven't had a car setup in like 2 years. I guess I just lost interest or money. But I've got this HT subwoofer project in progress with 2 ED 12kx.22 and a 6cube box tuned to like 21Hz. Almost done the construction part. I've had these subs since Jan 2004.
I am an amplifier internals freak. I am a graduated Electronic Technician.
0 -
Hi,
I am regular at SIN and found this forum to be interesting so I joined.
0
Mod on the 2000x
in US AMPS
try e-mailing the company?
