Posted April 7, 200817 yr My question is, is it worth it to double up on 3/4" mdf on all sides, or should i just strengthen the side holding the sub? 18" Fi Bl--- p chamfer and flatwind39"x18"x22" (sub is on 39x22 side) tuned to 34.4xxx hzany suggestions? thanks.also, this is a daily driver, not going to a termlab anytime soon, just want it to be a good, solid setup for daily driving. Edited April 7, 200817 yr by QuestionMan
April 7, 200817 yr it doesnt hurt too but it also doesnt take the place of bracing either.It prevents flex better than single layer but bracing is still necessary.
April 7, 200817 yr Author what's your favorite way to brace then? I've seen some people just cut 2x4s and that seems like it'd take up a lot of volume...
April 7, 200817 yr double 3/4" the speaker mounting side, 2x4's for bracing, seems to be popular.threaded rods work as well....
April 7, 200817 yr All thread comes in any where from 3ft to 6ft pieces and sometimes longer. That's what I use for bracing on large surface area boxes if the port can't do the job.
April 7, 200817 yr Author Alright last question (thanks to everyone for replying). How thick should i have the threaded rod be? Edited April 7, 200817 yr by QuestionMan
April 7, 200817 yr <--double walls enclosures and regularly triple bafflesAlthough my needs may be a bit different than yours.
April 7, 200817 yr <--double walls enclosures and regularly triple bafflesAlthough my needs may be a bit different than yours.lol, you think???wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
April 8, 200817 yr <--double walls enclosures and regularly triple bafflesAlthough my needs may be a bit different than yours.lol, you think???wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee At least I state it
April 10, 200817 yr damn thats crazy... lol ive only herd of that kind of stuff for spl walls. I was pretty amazed at the box i had built for my XXX's with the double baffle. I may have just missed it but i havent noticed any flex (then again i havent played them full volume)
