Posted January 9, 200916 yr Ok, lets dispell some myths about speakers. I figured we could have a small list of the different ways you could "blow" a speaker and have a little technical explanation to go with it. I also want to talked about clipped and unclipped signals and thier effects on a speaker.Ways to blow a driver1. Degrading of materialsThis one is plain and simple. Speakers get old. Typically when a speaker gets old the surrounds go first, especially in stock speakers. most surrounds are made of a foam or rubber and time, heat, sunlight (common in dash mounted speakers) cause the materials to degrade, and then when you play them again they fall apart.2. Thermal Limits of a driverWhen a driver is given too much power the voice coils can be burned and ruin the driver3. Mechanical Limits of a driverIt certain enclosures and with a low enough frequency a speaker can reach its mechincal limits, which is commonly known as "bottoming out" the driver. If this happens enough the driver can tear itself apartClipped and Unclipped signalsDoes a clipped signal kill a speaker? If you give a 1000W speaker a 100W Square wave or clipped sin wave will it tear the speaker apart?Obviously my answers arent' the best so, I'm leaving this open to all to elaborate on. I am at work right now and can't be typing too much . If you answer one of these tell which one you are answering and make a good consice set of statements, and then I'll edit my original post. Also any other good questions are welcomed!
