Posted May 6, 200917 yr I decided to build a kind of fart box for a local comp to get higher scores. and while i was designing it i thought i could make a second port for daily use and shove it through my backseat. I wanted to get a box for two 15s in the car but the most space i could get with the design i had in mind was 2.375 cubes per sub and i want more. so ill be using this box for this month then work out a new design based on this new box to get 2 15s in my trunk. this box will be a little over 4 cubes, with an external flared port, and lots of threaded rod and carriage bolts.i spent most of the day getting this far
May 6, 200917 yr Author thanks everyone.i had to use a hand saw(whats that??) to finished the kerf cut cuz my tables saw wouldnt cut high enoughi should have more done tonight, then more pics.
May 6, 200917 yr Author i got a little more done.I got the holes drilled to mount the port and the t-nuts put in. started on the inside kerfs
May 7, 200917 yr ive thought about doing something similar. good to see someone else pull it off since im too lazy to try. nice work sir!
May 7, 200917 yr looks really cool man, what made you decide to the port like that over a regular port or aeros
May 7, 200917 yr Author thanks all of yall. I wanted one big port and i wanted it flared. the biggest aero port was 6 inches. i saw how to make kerfs, tried it, and it was pretty easy. So i decided one a big square flared port. It came out better than i thoughtI have more done including an inside flared part, the pics will be up soon.
May 7, 200917 yr Author that is so SICK man post so vids asapi might not do a vid of this port because its tuned at 49hz for comps. but after i get the box in the car i can measure for my daily port. after that ones built ill make some vids
May 8, 200917 yr Author I had a few finals today so i didnt get much done.I got the top baffle on. i just using a single baffle because ill have threaded rod for bracing. I also sealed the edged with more fiberglass and made more 45's from resin. I didnt get to many pics of it since fiberglassin gets pretty messy.I also got some toys today..sorta^^ wat i get for bein on ebay at 3am I found some 3in air sander disk things 25 for $20 nice deal, some rubber grommets. 150 with different sized i think it was $7. and 2 fuse blocks.. i ran into a problem with my alt to batt wire got laid on my header and came about a millimeter from melting throught the wire loom and wire jacket. so now i wanna fuse both ends just to be safe. Ill get a pic of wat the wire looks like.
May 9, 200917 yr Author I got a little more doneI cut the whole for the sub, put it some t-nuts, and put in the threaded rod. now i just have to find my small bolts to make the terminals. I used some carriage bolt with the theaded rod mainly to keep the bottom of the box close to flat so it lays down betterthose expensive little things. almost $4 eachi had to screw that nut over 3 feet. then i had to do it again for the other one. Edited May 9, 200917 yr by fritosaregood
May 9, 200917 yr I got a little more doneI cut the whole for the sub, put it some t-nuts, and put in the threaded rod. now i just have to find my small bolts to make the terminals. I used some carriage bolt with the theaded rod mainly to keep the bottom of the box close to flat so it lays down betterthose expensive little things. almost $4 eachi had to screw that nut over 3 feet. then i had to do it again for the other one.looks fudgeing sic internal sshot
