Posted July 3, 200619 yr ok my friend will build me a box in his wood shop but i need to get him plans. SI 15 MAG, ported. what do you think of the aeroports? is it worth it for only $25 extra? most people use 2 of them at $12 each. power will be a hifonics ZEUS 1000D 1000@1ohmit is a lexus 2002 es300. should be the same as the new camrey. people have put 2 15 in there before with a almsot bent box. i only need 1.the red strap is what i will be using to hold the sub in place, i would also love there to be ehough room to put my trunk battey next to the box. it is 6.5 inches widedemetions are (IMG:http://members.cox.net/havok/trunk.jpg)THANKS FOR ALL THE HELP I AM FINALLY BUYING A SUB TO FINISH MY AUDIO SYSTEM AFTER 2 YEARS!!!!!
July 4, 200619 yr YOu can use whatever you want for vents. A slot vent would be cheapest and easiest, but depending on tuning, they can take up quite a bit of volume and necessitate a rather large enclosure.
July 4, 200619 yr heres the box i built for a mag 15 i dunno if it will fit or noti know the hole cut out says 11" but its 14" i screwed up when making the labels Edited July 4, 200619 yr by splblazer98
July 4, 200619 yr Author OMG thanks so much.when we build it, i'll try and get a GOOD pic for you.how was this done cad? or a program for boxes.did you screws on top where the port was? 3/4 mdf is what i want to use.so how did it hit? with how much power?will this fit over it and not let the sub hit it. http://www.cardomain.com/item/RTEGP15thanks a lot, i owe you one let me know if i can help you with anything.fixed the pic for you Edited July 4, 200619 yr by havok13154
July 4, 200619 yr A conventional grill wil not fit. The only available grill that will work will be the bar type grills such as this:http://www.partsexpress.com/pe/showdetl.cf...tnumber=260-444
July 4, 200619 yr Author damn i really want somehting for protective. when i get it i'll mesure it and dubble it and then if i can make a baffle around the sub then get the standard one but it will be rasied.
July 6, 200619 yr bar grills dont stop much as far as punctureing the cone. just stuff pressing agianst it.
July 6, 200619 yr Author what do you think of this grill? will it clear?http://cgi.ebay.com/1-SOUNDSTREAM-15-GRILL...1QQcmdZViewItem
