Posted July 15, 200718 yr If using an outboard EQ and a seperate outboard crossover, which should come first in the signal path? The EQ or the X-over?
July 15, 200718 yr Author EQ has to unless you have one for each output of the x-over.Would that be a better option? A dedicated EQ for each channel?Doesnt Audiocontrol make a 6 channel EQ?
July 15, 200718 yr yeah it's called the EQS..that along with maybe like the 6xs would be one solid SQ set-up....
July 15, 200718 yr Author So with dedicated EQ's per channel, would you still put the crossovers after them in the signal path?
July 17, 200718 yr Author No, if you had an EQ per channel it would go HU > X-over > EQ'sOh yeah....duh.
