Posted July 23, 200718 yr to power a 15" or 18" Q should i usa a autotek mm 1400.1 or ss 1500.1?the reason i ask is becasue i have seen a few test done where the ss500 and i think the 1000 did there rated power around 13.8-14 volts. or should i go with the mm1400 and i am getting a good deal on the amps so they are the only 2 i can pick from.
July 23, 200718 yr there is a review on the net where i think car audio bench tested the mm1400 and got 1700w at 1 ohm. so i bet it can do the 1400 without any major distortion. i own 2 and they love current. i did get some weird feedback in 1 but it was because i had an rca too close to a power wire and the gain a smidge high.**edit** found the reviewhttp://www.caraudiomag.com/testreports/061...0_1d_amplifier/ Edited July 23, 200718 yr by ScottXGTR
