  • Replies 144
  • Views 21.5k
the problem :
thought about one fix :
the ring is on the inside part.
once the baffle is in place i'll lay some layers of fiberglass to connect the narrower parts to the enclosure.
1 inch mdf for the baffle and 3/4 inch for the ring.
the lower edge will be supported by another mdf panel. only trouble i still have is on the upper part. that's where i plan on using fiberglass to reinforce. there are bolts in the t-nuts to stop the resin dripping.
also ran out of resin so the left side onle has chopped mat.
it's going to be fun removing the bolts :D
the panel thas is going to support the lower side. there is a nut in that hole :D
  • 2 weeks later...
almost done with the glassing part :D
beware, it looks rather ugly from the excess wood glue
that's my attempt to reinforce the thin mdf lip. also fiberglassed a nut in there..for mounting purposes :)
rear of the enclosure
thinking of covering the visible parts in leather and painting the hidden parts black.
the last pieces of resin are starting to cure.
Dude....................freakin sick.
I end up in the Netherlands, if I gots a garge ur gonna come teach me to glass right?
J
Looking good sir. little late for this tip now , but in the future if you need to glass around nuts and bolts. Coat the bolt in vaseline ( petroleum jelly ) first , then thread it into the nut . THe resin won't stick to the vaseline :)
He's in Romania... a bit out of the way from the Netherlands.
24-26 hours with the car :)
plus i never been there (only Germany and Belgium).
if you're there this summer we'll arrange a meet :D
sir Ramos, thakyou for the advice. i never thought about vaseline. it's something i'll do for sure next time i need to glass bolts.
I will let u know when the time comes man.
We may have some stuff to do when I get there neways LOL
J
nice sir!!
now, pictures of packages sent to you!!
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
nice build log... cutting up all those pieces of deadner mustve taken forever awesome work... cant wait to see the final product
  • 4 weeks later...
Great build !!! any pics of the finished boxx ?
what kind of cloth is that your using for the FG ?
  • 6 months later...
I'm baaaaaack :D
Time to finish sound deadening the floor and build an enclosure for the Rl-i.
The back panel of the enclosure is almost complete. Doesn't sit perfect on the plastic panel :(. The top sagged but it's already cut and ready for a repair. No pics of the enclosure...yet. At least it's better than my first box.
Picked up the sound deadening today and as soon as I'm done with the fiberglass, I'm going to finish the floor.
I just read through the whole build and it looks great. You definitely did an awesome job with the fiberglass, keep up the good work!
Looking good mr. adrian. Looks like you pulled the mold out before the glass had fully cured. It tends to warp :(
Easy way to make it flush is to tape the area back up. except this time only tape up the plastic around the edge of your mold. THen set your mold back in on the tape. Now you can go crazy with some reinforced filler and fill in the gap between your mold and the tape. Let the filler cure fully and pull it out. Viola you just matched that shape perfectly with next to no effort at all :)
Thank you sir ! I appreciate the comments :)
I forgot to mention I added too much hardener to the mixture and in a corner it got really hot and even smoked. Scared me and I had to pull it out :(
Nothing done today except measuring the volume. Ended up at around 0.56cf. With some fill it should be good for the RL-i10 :)
