Posted August 1, 200719 yr I cant figure out where to lay the 0 ga wire so it wont show under the carpet!any suggestions?
August 1, 200719 yr Does the car really make that much of a difference?Well, if all cars were manufactured the same no..But as far as I know, they're not.
August 1, 200719 yr Author That still does not answer the question, where is the best place to lay the wire?
August 1, 200719 yr where is the best place to lay the wire?For that vehicle, I don't have a lot of experience with unibodies so I can't help you much.I'd just start pulling carpet and see if there's any channels or places you can fit it.
August 4, 200719 yr Usually you can go under the door sill or right next to it. Have two runs of 0ga in the Neon right there and you wouldn't know unless I told you. There's a channel there for the factory harness with plenty of extra room.
August 6, 200719 yr yea you jus kinda gotta man handle your foot step things where the bottom of your door is and lay it there prob easiest way
