August 2, 200718 yr YOu mean what is the difference between amplifier classes? A monoblock is nothing more than one single channel amplifier. A dual monoblock amplifier is essentially just one chassis with two amplifiers. And likewise.
August 2, 200718 yr Author YOu mean what is the difference between amplifier classes? A monoblock is nothing more than one single channel amplifier. A dual monoblock amplifier is essentially just one chassis with two amplifiers. And likewise.Well i see this all the time on websites they will have one section for each, cant see any difference.
August 2, 200718 yr Not all monoblocks are Class D, and not all Class D amps are monoblocks...they're two different things.
August 2, 200718 yr Author Not all monoblocks are Class D, and not all Class D amps are monoblocks...they're two different things.Well, What are some things that make them different?
August 2, 200718 yr Like Tirefryr said, a monoblock is a single channel amplifier.Class D is an amplifier topology where the output devices are switched between full on and off states, hence why some people (incorrectly) refer to them as "digital" amps.
August 2, 200718 yr What are the differences between the 2 if there are any? Monoblock describes how many channels the amp has, that being one. A Monoblock can be any class.Class-D is an amplifier topology describing how the amplifier works. A Class-D amp can have any number of channels but they are usually monoblock as the Class-D design is best suited for subwoofer duty. Some new technologies take Class-D full range... but in general, Class-D is used for woofers.
August 2, 200718 yr Author Class D is an amplifier topology where the output devices are switched between full on and off states, hence why some people (incorrectly) refer to them as "digital" amps.Ok, that was all i needed to know, thanks to all
August 3, 200718 yr Dude, your avatar is fucking SICK! That would be so badass as a tatoo. Do you have a full resolution copy?
August 3, 200718 yr Have you had a chance to listen to the pdx yet ? I have read all the reviews , but would like an opinion from someone who isn't paid for ad space
August 3, 200718 yr Dude, your avatar is pucking SICK! That would be so badass as a tatoo. Do you have a full resolution copy?I really wanted to say that , I was looking at it and salivating!
August 3, 200718 yr Have you had a chance to listen to the pdx yet ? I have read all the reviews , but would like an opinion from someone who isn't paid for ad space Sound wise... I haven't noted a single thing different compared to any Class A/B I have used. Once I get the front end installed, I'll be doing more critical listening.They do heat considerably, but that is part of the design too.
