Posted August 2, 200718 yr What would the recommended wattage be for a single 18 run in an IB set up?
August 4, 200718 yr Author What would the recommended wattage be for a single 18 run in an IB set up?Any one biting out there?
August 4, 200718 yr Something like 500 watts would bring you to xmax at 20 Hz. If you set gains well and watch the level you play at, 1000 watts would be good for headroom and transients.
August 4, 200718 yr hmmmm I think it would be something like 350/400Wrmsedit did not see the post^^ Edited August 4, 200718 yr by JEREMIAH....
August 17, 200718 yr Most of the mass produced subs I find that actually say anything about IB use recommend roughly half the rated power. I have 4 12s and thought about trying fewer but better drivers. I've always used cheap subs IB but lots of them to get away from the travel issue. I like to push 30Hz out of them. I'd like to hear a good quality 18 or two 12/15s IB. Edited August 17, 200718 yr by sqguyib
