Posted August 3, 200718 yr I actually have a few questions. I have two different box ides. If I build a box with the sub facing UP, and fire the port into the car, will i lose spl? And as well, if i build a box with the Sub facing UP, and the port facing up, will I have a greater, or same as the bass response from firing the sub to the rear of the trunk. In other words, will facing the port in a different direction then the sub, affect the spl factor of the sub.
August 3, 200718 yr In other words, will facing the port in a different direction then the sub, affect the spl factor of the sub.It very well could.Only way to know in your case is to test...which if you care about SPL you should be doing anyway.
August 3, 200718 yr Author and could someone inform me how to use the aero ports? im not sure how to tune using them.Thanks
October 4, 200717 yr and could someone inform me how to use the aero ports? im not sure how to tune using them.Thanksfor aero ports u must no the dimensions of them first...and yes facing the ports is a factor... but also depends on the vehicle.....testing is probably the best way to do it
October 4, 200717 yr Echo echo echo echo echo echo echo.Neil (DevilDriver) has a write up on how to tune aeroports in the technical/how-to section.
