Posted August 8, 200719 yr Has anyone done a wall or anything with 4 mj 18's yet? im kinda curious if anyone has and what type of box they decided to go with. Figure with the 3 for 4 deal someone must have put 4 in a van or suv!
August 9, 200719 yr In car? Haven't seen it yet. In home? Plenty of times, usually IB though.I'd suspect you'd need around 20ft^3 after displacements ported.
August 9, 200719 yr Author well thats why i said suv\van just cause i know you would need a chit ton of space, but i thought someone would have tried it. yea people seem to really like them for IB but i cant do an IB right now so id like to toss 4 in my van
August 12, 200719 yr You would be the first I've heard of if you decide to go thru with it. You can share the experience(s)..
August 12, 200719 yr You would be the first I've heard of if you decide to go thru with it. You can share the experience(s)..I almost talked my buddy into getting 4 . He settled on 2 lol
August 12, 200719 yr one of my friends has 4 in his astro right now, i believe the plan is to eventually add 4 more for bassrace 140-149. I don't know if he's a member here or not but his user name is the mommy van on caraudioI haven't heard it yet. was supposed to today but i woke up too late so i just didn't go to the show.
August 14, 200718 yr one of my friends has 4 in his astro right now, i believe the plan is to eventually add 4 more for bassrace 140-149. I don't know if he's a member here or not but his user name is the mommy van on caraudioI haven't heard it yet. was supposed to today but i woke up too late so i just didn't go to the show.how big is that box and what's it tuned to? How much port area is he using?
August 15, 200718 yr sorry i didn't get back to you guys sooner. i'll send him over here. Edited August 16, 200718 yr by profundus-sanus
August 16, 200718 yr Sorry dont get over here much since they changed it. Profoudus told me about this thread. The box is 18.3 cubes before sub dis. with around 380 sq. inches of port tuned to 31. They are the single 8 ran at 2. Off of a Powerbass ASA 2000.1.I did an 143.4 @ 45 HZ.with no tuning. Just received a Massive audio P3000.1 (3k@2 for those who dont know). Its in a 97 astro van. it fits behind the second row of seats and about 3 inches above the window line. Edited August 17, 200718 yr by Stu Padasso
August 17, 200718 yr Author well the plan is in motion now for 4 mj 18's i do belive it was either that or 1 18" btl but...i havnt gotten ahold of mark in the last few days but thats okay, im sure hes a busy guy so ill again tonite the single 15 BTL is just not enough need way more
August 18, 200718 yr I will say this 380 sq inches of port is to much they should be fine with about 200-300
August 21, 200718 yr thanks for the info. I plan on putting 4 of those mj's in my astro.Thats what I have mine in. A 97 astro.
August 27, 200718 yr i just ordered 4 MJ's for my explorer..running at 1 ohm off a modded HK4000D. probably at 2800rms. sealed at first but ill be building a ported box at the same time. ill use the ported box for special occasions but its too big to be practical for every day considering im aiming for 17 cu ft net so like...22 cu ft gross. ill keep pics
