Posted August 10, 200718 yr whats going on guys, i need a little advise on amps. a month or so ago i finally blew one of my old 12's after years of abuse. i decided to replace them with the kicker 12 inch cvx's(4ohm). problem is the kickers are literally sucking the life outta my old amps, so iv been lookin to up grade them as well. i really like the kicker zx series but its kinda expensive. my question is. i can buy 2 zx750.1 cheaper than a zx1500.1. would this be the way to go? isnt it the same power? witch would cause a larger draw on my charging system? i dont have much experence with mono block amps. arnt u only suppose to use one speaker on one mono block? someone told me to get the 1500.1 and wire it to both speakers. is this just a matter of having to sets of wires going to the one output of the amp? apprecate the help in advance.sorry for the spelling
August 21, 200718 yr whats going on guys, i need a little advise on amps. a month or so ago i finally blew one of my old 12's after years of abuse. i decided to replace them with the kicker 12 inch cvx's(4ohm). problem is the kickers are literally sucking the life outta my old amps, so iv been lookin to up grade them as well. i really like the kicker zx series but its kinda expensive. my question is. i can buy 2 zx750.1 cheaper than a zx1500.1. would this be the way to go? isnt it the same power? witch would cause a larger draw on my charging system? i dont have much experence with mono block amps. arnt u only suppose to use one speaker on one mono block? someone told me to get the 1500.1 and wire it to both speakers. is this just a matter of having to sets of wires going to the one output of the amp? apprecate the help in advance.sorry for the spellingget 2 2ohm subs, to get a 2ohm load on the amp, and get the zx1500.1, the amp is made to power 2 12" L7, and 2 12" CVXive lookin at the same setup but i think i might go with Fi audio
August 21, 200718 yr Two 2 ohm SVC subs can't be wired to a 2 ohm load, either 1 or 4.arnt u only suppose to use one speaker on one mono block?As long as the impedance stays above the minimum that the amp can handle, it's fine.
August 21, 200718 yr 1500rms don't mean to jack your thread but i wanted to ask you about the CVX. what do you think of them as SQ? SPL? LSQ? did you find a review?
August 21, 200718 yr 1500rms don't mean to jack your thread but i wanted to ask you about the CVX. what do you think of them as SQ? SPL? LSQ? did you find a review?really just an output sub
