Posted August 19, 200718 yr I have 4 4 ohm 10's in my car now, wired to 1 ohm for my saz-1500d. I am thinking of upgrading to 4 12's. The 12's I am looking at only come in dvc config, so to get 1 ohm, i need to get dvc-2's. My question is should I wire the coils on each sub series and then wire the subs parallel, or vice-versa? Would it make a difference to the amp? I would end up with a 1 ohm load either way. Any help would be appreciated.
August 19, 200718 yr Doesn't really make a difference, but one-way or the other could be easier to wire up or could use less wire. Depends on how your install is setup.
August 19, 200718 yr Author The amount of wiring isnt an issue for me, just the performance of the system is my number one concern.
August 20, 200718 yr Author Thanks for the diagram jon, but I know how to wire it. My question was if the way you wired it( with each pair of coils wired in series) would be any better for output, or sq versus wiring each pair of coils parallel, then each pair of subs in series( 2 ohms per pair) then each pair of subs in parallel to the amp to achieve 1 ohm at the amp. Like this:sub1: coil1pos to coil2 pos, coil1 neg to coil2 neg...1ohms.....wire to sub2 in series to get 2 ohms for the pair..... wire to other pair in parallel to achieve 1 ohm.So, a parallel/series setup vs a series/parallel setup.Thanks
August 21, 200718 yr My question was if the way you wired it( with each pair of coils wired in series) would be any better for output, or sq versus wiring each pair of coils parallel,Nope.
August 21, 200718 yr Yeah, like they said, its not going to matter.There are some extreme cases in SQ comps where wiring them different can do something for your, but in this case.. go with the easiest option as pictured.
August 30, 200718 yr If you listen to Manville Smith of JL Audio, subs should be wired in parallel whenever possible. The coils of each sub can be wired in whatever fashion gives you the final impedance that you need.
September 3, 200718 yr Electricity is pretty dumb and won't really know the difference in the end product. 1 ohm into the amp is 1 ohm (am I wrong?).
September 8, 200718 yr The idea is that with the series wiring between subs the current from the amp has to go through one sub to get to the other. Any nonlinearity in either sub can therefore affect the signal going to the other sub through back EMF. With parallel wiring the amp acts as a shunt to limit the amount that the sub interact electrically with each other.
September 9, 200718 yr wired in series changes the bl force of the driver which helps a little when it comes to the lows, i noticed that when i changed around my clarions, i had less power, went from about 1500Wrms to something like 500Wrms and it seemed to have way better low end to my ears.
