Posted August 25, 200719 yr As the topic says, thinking about powering two 15's off a buttkicker bka1000-4A amp. 2000w@2ohm 1000w @ 4ohm but I
August 25, 200719 yr The buttkicker was tested over at avs and was found to only produce 1000@ into 2 ohms. In addition to this the distortion got all the way up to 14%. I have one powering a rlp15 and it sounds great to me but obviously thats just my opinion. Im sure if you ran a search over there you could find the thread.
August 25, 200719 yr Author Thanks for the reply,I figured the amp was a little overrated, definitely won
August 26, 200719 yr I haven't dealt with them but I noticed there is some negative feedback about them.http://www.soundsolutionsaudio.com/forum/i...sound\.comJust something to be aware of.
August 26, 200719 yr they are chit for customer service. i bought three items from them, they sent one. i asked why they didn't send the other two, a week later i got "not in stock" i asked for a refund three times and calll them anoth four times. took over a month to get a refund.
August 26, 200719 yr http://www.soundsolutionsaudio.com/shop/in...mp;productId=24that amp should work good bridged right? that way it will b from a site i trust and like and i will save money lol o and get another ssa sticker for the other side of my window
August 26, 200719 yr I've ordered stuff from Ike before and had it go perfectly. I've also had orders go bad too.The majority of orders that people have had with them are bad.
August 26, 200719 yr Might be a good idea to stick with a Class D amplifier, for efficiency sake.Budget? You need ~1k @ 1ohm.
August 26, 200719 yr http://www.cadencestore.com/ProductCart/pc...p;idproduct=380not bad.. im guessing you trust that site.. loland my budget is about 300.. but the cheaper the better but i dont want a pos amp either
