Posted August 25, 200719 yr Whats up guys this is Rp i own a car audio shop in Lafayette IN i am running street c this year and looking for new amps... currently using 4 Memphis 4kw and pro-comp subs. looking at the 3000 watt ssa but i need test results on them... volt drop\ power\ ohm\ and amp draw
August 25, 200719 yr The results are pinned right at the top of the Sundown Audio forum.http://www.soundsolutionsaudio.com/forum/i...?showtopic=9952
August 25, 200719 yr Ren, is that you?no its rpWell tell Eric I said "What's up, fucker".I haven't talked to him in a while.
August 28, 200719 yr Wow, am I reading this right. RP the owner of Sound Check is actually on the forums. haha whats up buddy
August 28, 200719 yr Author Wow, am I reading this right. RP the owner of Sound Check is actually on the forums. haha whats up buddywhats up bro.... yes actually thinking about running the 3000 in the rex for this year.hit me up this weekend.
September 8, 200719 yr Author ok... memphis 4kw @.35 and .175 per amp volt drop 10.8 3000 @1.4 and .7 per amp volt drop 11.3 .7 gair so far Edited September 8, 200719 yr by Sound Check (RP)
September 10, 200719 yr Jacob tried to test them that low, but I believe the wattage gains werent as impressive as 0.5 DCR was.PLus it was drawing a lot of power at that point and efficiency was down.
September 10, 200719 yr Have you tried the Memphis higher I meant, they might keep the voltage up that way.
September 11, 200719 yr Author memphis 4 kw at 1.4 and .7 per amp volt goes to 12.03not nearly as loud... awsome amps though...used them for a full year and never droped one... just power hungrycan only get one burp out of the 4 kw and then need to charge alot... sundowns 6 burps and saw a .05 drop in score
September 17, 200719 yr Author Max-link is in...... no gain yet but 10 burps = the same number...###.##
