Posted August 26, 200718 yr http://www.soundsolutionsaudio.com/shop/in...p;productId=108What is that amps peak power, if 500watts is RMS?Also does it include a bass controller? and can I set my subs to run off a switch so that I can turn them on and off.
August 26, 200718 yr Who cares what the peak power is?It looks like it has a remote controller as an accessory, but doesn't say it's included, so I wouldn't assume so.A switch like you're talking about can be wired into the remote turn on for the amp, just a simple SPST (single pole, single throw) toggle switch does the job.
August 27, 200718 yr not sure what peak is or why it is relavent but rated is 125x 1 @ 4250x 1 @ 2 500 x 1 @ 1actual is more then rated probaly like 200 x1 @ 4 , 400 x1 @ 2 , and 700 x1 @ 1 real closer to that if not more
August 27, 200718 yr Peak power is meaningless.Not sure on the bass controller, of course I don't really understand the need for one either.As for your question on turning it on and off, it is pretty easy to wire a single throw switch in line with your remote turn on wire.
