Posted August 27, 200718 yr For purely academic purposes, imagine a ported enclosure tuned with 2 aeroports.If the aeroports were different lengths...and therefore different tunings, what would the net result to the listener be?Would the box only keep one tuning?...would the tuning freq be "spread out"?...would space/time warp and fold back on itself thereby negating this whole exercise?Thanks
August 27, 200718 yr I made this analogy in a thread earlier....A single speaker (no enclosure) is simply a diaphragm with mass on a spring that is driver by an electromechanical motor. The motor is obvious: the voice coil, it's interaction with the flux from the top plate, magnetic stack, backplate, and pole piece. The spring is the spider and surround. The diaphragm with mass is the diaphragm itself (plus the mass of the other moving parts).Now a bass-reflex enclosure behaves on the same kind of principle. The air inside the port is the mass, the air inside the enclosure is the spring, and the motor is the speaker itself. If you imagine this visually, it should be easier for you to understand the answer.The enclosure itself behaves as a low-pass filter. Just like any filter, it has a Q factor, resonance frequency, rate of rolloff, etc. It's the combination of Q factor and resonance frequency that is really the question here, as the rate of rolloff for most bass reflex enclosures is around 24dB/octave (4th order). By introducing two ports with different frequencies at which they resonate, you essentially end up with two different diaphragms with two different masses. Yes, this is in fact a LOT like putting two different speakers in the same enclosure and having them share airspace. It's not a particularly efficient use of the air spring.Note: An aperiodic bi-chamber (ABC) enclosure does work. Using the above analogy, can you explain why?
August 27, 200718 yr some one that post on car audio talk forum name AZNBOI has a JL audio sub in a ABC box and says it sounds nice
August 27, 200718 yr Author I made this analogy in a thread earlier....A single speaker (no enclosure) is simply a diaphragm with mass on a spring that is driver by an electromechanical motor. The motor is obvious: the voice coil, it's interaction with the flux from the top plate, magnetic stack, backplate, and pole piece. The spring is the spider and surround. The diaphragm with mass is the diaphragm itself (plus the mass of the other moving parts).Now a bass-reflex enclosure behaves on the same kind of principle. The air inside the port is the mass, the air inside the enclosure is the spring, and the motor is the speaker itself. If you imagine this visually, it should be easier for you to understand the answer.The enclosure itself behaves as a low-pass filter. Just like any filter, it has a Q factor, resonance frequency, rate of rolloff, etc. It's the combination of Q factor and resonance frequency that is really the question here, as the rate of rolloff for most bass reflex enclosures is around 24dB/octave (4th order). By introducing two ports with different frequencies at which they resonate, you essentially end up with two different diaphragms with two different masses. Yes, this is in fact a LOT like putting two different speakers in the same enclosure and having them share airspace. It's not a particularly efficient use of the air spring.Note: An aperiodic bi-chamber (ABC) enclosure does work. Using the above analogy, can you explain why?Possibly, with some research....that, more than likely, will not happen. You said this is not an EFFICIENT use of the air-spring...does that mean that it is a "bad" use of the air/spring?Thanks for the insight...I highly enjoy reading your posts.
August 27, 200718 yr Author some one that post on car audio talk forum name AZNBOI has a JL audio sub in a ABC box and says it sounds niceI used to have some ABC gum.
August 27, 200718 yr I made this analogy in a thread earlier....A single speaker (no enclosure) is simply a diaphragm with mass on a spring that is driver by an electromechanical motor. The motor is obvious: the voice coil, it's interaction with the flux from the top plate, magnetic stack, backplate, and pole piece. The spring is the spider and surround. The diaphragm with mass is the diaphragm itself (plus the mass of the other moving parts).Now a bass-reflex enclosure behaves on the same kind of principle. The air inside the port is the mass, the air inside the enclosure is the spring, and the motor is the speaker itself. If you imagine this visually, it should be easier for you to understand the answer.The enclosure itself behaves as a low-pass filter. Just like any filter, it has a Q factor, resonance frequency, rate of rolloff, etc. It's the combination of Q factor and resonance frequency that is really the question here, as the rate of rolloff for most bass reflex enclosures is around 24dB/octave (4th order). By introducing two ports with different frequencies at which they resonate, you essentially end up with two different diaphragms with two different masses. Yes, this is in fact a LOT like putting two different speakers in the same enclosure and having them share airspace. It's not a particularly efficient use of the air spring.Note: An aperiodic bi-chamber (ABC) enclosure does work. Using the above analogy, can you explain why?Hopefully one day i will be able to write a post like this one.
