September 14, 200718 yr play them for a long time they need to break inbox looks like it should move air though! chitty deals man hope you find somthing to make you happy
September 16, 200717 yr Author play them for a long time they need to break inbox looks like it should move air though! chitty deals man hope you find somthing to make you happy Worked on the box today and figured out what was wrong. I made the port to long was tuned to 27.5 hz. Which made the box Cut it down and put 45s in the corners and Hairtricks away. Now have to move radio to the rear sealed off section so it stops skipping.
September 17, 200717 yr hair tricks you say well...i was planning on waiting until summer todo my wall...damm you!! i wanna do hair tricks .... nice work
September 17, 200717 yr Author hair tricks you say well...i was planning on waiting until summer todo my wall...damm you!! i wanna do hair tricks .... nice work Well I need to get on the meter and see if Im the first to 150 with Mach 5s. I have to beat you. At least you could say your the first in canada.
September 20, 200717 yr hair tricks you say well...i was planning on waiting until summer todo my wall...damm you!! i wanna do hair tricks .... nice work Well I need to get on the meter and see if Im the first to 150 with Mach 5s. I have to beat you. At least you could say your the first in canada. well 150 db in a family van beats anything i can do
September 20, 200717 yr Author meh......what about 160's Not for the wife. I was originally going to use 8 or 12 18s seale din the same space. But I know how my wife is. Will have new pics this weekend.
September 20, 200717 yr hair tricks you say well...i was planning on waiting until summer todo my wall...damm you!! i wanna do hair tricks .... nice work Well I need to get on the meter and see if Im the first to 150 with Mach 5s. I have to beat you. At least you could say your the first in canada. well 150 db in a family van beats anything i can doCurrently...
September 21, 200717 yr Author hair tricks you say well...i was planning on waiting until summer todo my wall...damm you!! i wanna do hair tricks .... nice work Well I need to get on the meter and see if Im the first to 150 with Mach 5s. I have to beat you. At least you could say your the first in canada. well 150 db in a family van beats anything i can doCurrently...Also remember this is a bass racer not a fart machine. Im sure I could do 160 if I made it a fart machine.
October 2, 200717 yr Author Well after having these subs for awile now I think I'm going to have to change them out. I think Im asking to much out of them. There not liking my amp at the moment every time I turn them up I start to smell the coils on them. Im only feeding them 750 rms I think its just to much for them. I have a show to go to on the 21st of OCT so I'll try and get a vid of them going up. Edited October 2, 200717 yr by Stu Padasso
October 18, 200717 yr Author Its been a little bit since the last update son to some new pics. Changed the box so I can change the port tuning if needed. Also for those who kept asking about bracing I think this might be enough. Still have the double baffle and trim panel to do.
October 18, 200717 yr Well after having these subs for awile now I think I'm going to have to change them out. I think Im asking to much out of them. There not liking my amp at the moment every time I turn them up I start to smell the coils on them. Im only feeding them 750 rms I think its just to much for them. I have a show to go to on the 21st of OCT so I'll try and get a vid of them going up.Its very possible..
October 18, 200717 yr what ohm are you running that Massive at ???i ran mine bridged @ 2.3ohm and it poped... if the coils are getting hot thats not a bad thing just turn the gain & bass Boost down
October 19, 200717 yr Author what ohm are you running that Massive at ???i ran mine bridged @ 2.3ohm and it poped... if the coils are getting hot thats not a bad thing just turn the gain & bass Boost downSits at 1.8. Also I think I found some of the problem. I had a bad battery. As soon as I unhooked it from the others it went to 10.3 and the others sat at 13. So I might have had some clipping going on.
October 22, 200717 yr Author If I had brought my 40 hz port I might have been able to do it. But I forgot it at home
October 22, 200717 yr what ohm are you running that Massive at ???i ran mine bridged @ 2.3ohm and it poped... if the coils are getting hot thats not a bad thing just turn the gain & bass Boost downSits at 1.8. Also I think I found some of the problem. I had a bad battery. As soon as I unhooked it from the others it went to 10.3 and the others sat at 13. So I might have had some clipping going on.1.8ohm bridged or per side ?mine was 2.3ohm bridged / went into protect and never recovered / was a nightmare dealing with Massive getting re[aired / bassiclly they blame the customer and wont warranty it
October 22, 200717 yr what ohm are you running that Massive at ???i ran mine bridged @ 2.3ohm and it poped... if the coils are getting hot thats not a bad thing just turn the gain & bass Boost downSits at 1.8. Also I think I found some of the problem. I had a bad battery. As soon as I unhooked it from the others it went to 10.3 and the others sat at 13. So I might have had some clipping going on.1.8ohm bridged or per side ?mine was 2.3ohm bridged / went into protect and never recovered / was a nightmare dealing with Massive getting re[aired / bassiclly they blame the customer and wont warranty itSo did u ever get it fixed?
