Posted September 25, 200718 yr How much power will an Saz1500d put out at around 1 ohm in a Honda civic with a stock alternator biggest battery that fits with out mods and an optima redtop in trunk? thanks for your time and have an awesome day. Zhttp://www.soundsolutionsaudio.com/forum/i...?showtopic=7116With one battery, stock alt (about the same as the Civic in output), 1510 watts @ 12.4 volts.With another battery, stock alt, 1635 watts @ 12.8 volts.So... between 1500 and 1600 watts or so, give or take a few percentage ---This battery fits in the newer Civic (this is mine). Only have to notch the battery tie-down, literally, that is ALL you need to do:
