September 29, 200719 yr theyll play just fine, like everyone else that has pro audio mids and just makes an enclosure for them,I'm 'ing at everyone else.
September 29, 200719 yr Author this is the only forum that anyone has mentioned about the mids/highs....i expect it from this forum though...
October 3, 200719 yr Author well you guys should be happy. i found about 14+ mounting points for the wall. ill post pics in a while, im working on it, removing seatbelt mounts in the rear, etc....those are just 2 of the mounting points i will be using. there's 2 really good ones behind the wall...i feel alot better now that i found all these mounting points, the wall will be very secure.
October 4, 200719 yr Author well i made some mounting points for the wall. its ugly, but its the only way i could get the bolts in there. it will be covered though, so it doesnt matter loltheres no bolts or mounting points at all up front (right behind the front seats)...only way i can get some bolts here would be to weld them to the floor...should i do that? is the gas tank right under that?the wall WILL be in, and bolted down tomorow!
October 4, 200719 yr Author heres what i got done today. its very sturdy, and i dont think its going anywhere. ill also have 4 huge bolts attached from the little rear seat latch things (that hold the vertical part of the seat in the upright position) to the back of the box, so those 4 bolts should keep the box from ever projecting forward in an accident, or at least help it alot from not just flying on me.bolted into the fuel pump area, and no, i didnt hit ANYTHING. lolthat bolt barely touches that wire loom, so its not harming a thing.the floor the box will be bolted and glued to.top of box is on.
October 5, 200719 yr Author the bottom the 3 little cutouts on the bottom are for the bolts to tuck in, so the box sits flat.the top and bottom side overhangs is so the 2nd side baffles go in there...gotta cut those tomorow.
October 5, 200719 yr I have to ask you......Why are you asking opinions on this board if when you get them you shoot them down or discount what they are ALL saying? I am sure you are capable of installing this system but you seem to want help but not willing to listen to it when its given. I quite honestly wonder if anyone else is even reading this topic anymore because of your responses. Have an awesome time and I wish you luck in your future endeavors.
October 5, 200719 yr Author lol idkthe last couple posts are just pics anyways, im not asking for help...just pics..lolif yall dont care, ill just stop updating, doesnt mean anything to me,.
October 5, 200719 yr theres no bolts or mounting points at all up front (right behind the front seats)...only way i can get some bolts here would be to weld them to the floor...should i do that? is the gas tank right under that?This is in one of the last two posts and you are asking for a response and you did exactly what I said you were doing. Why not shut up and listen. You do not have to do what is recommended but if you ask for help and someone gives it to you YOU should at least say thank you. I will not comment again on this I just thought someone should tell you how rude you are being towards the very people who are willing to help you for free.
October 6, 200719 yr Author naw im not gonna update this anymore, if anyone wants to see the pics, check ca.com or ROE
October 7, 200719 yr Author ah, what the hell, ill post pics. lolwall is in!excuse for me to suede the headliner lolhad a little mishap, dont flame, and it didnt fit in the very back, becuase im a noob, and didnt realize how far it would come back, and that the headliner dipped down in the back. oh well, easy fix, ill just put a 45 degree piece of 3/4" inside the box, seal it off, good as new.
October 7, 200719 yr naw im not gonna update this anymore, if anyone wants to see the pics, check ca.com or ROEfucking liar
October 7, 200719 yr I'm not really into the SPL machines, so I'm not going to pick your work apart. My only concern is that you're doing this to a MINI. I love those cars, but if I had one, it would be getting raced on the track, not in SPL contests. Nice looking car. Have you done anything to the engine? JCW stuff?
October 7, 200719 yr Author I'm not really into the SPL machines, so I'm not going to pick your work apart. My only concern is that you're doing this to a MINI. I love those cars, but if I had one, it would be getting raced on the track, not in SPL contests. Nice looking car. Have you done anything to the engine? JCW stuff?nothing to the engine yet, its a stock S with the JCW package.neon----how would you like me to build it? thow the hell would u build it inside the car...theres no room, you wouldnt be able to screw pieces together. if i recall, a wall IS a box....any sub enclosure is a BOX...
October 7, 200719 yr A wall seals off the cabin to reduce the area being pressurized. That? Does not.
October 7, 200719 yr neon----how would you like me to build it? thow the hell would u build it inside the car...theres no room, you wouldnt be able to screw pieces together. if i recall, a wall IS a box....any sub enclosure is a BOX...*cough cough* sounds like that's about the extent of what you're doing to me.....
October 7, 200719 yr I will wait to see, but do agree atm it is a box and not a wall. How much airspace do you have in that VJ?
October 8, 200718 yr Author wtf, EVERY wall is techincallly "a big box"honestly, do you guys read? i said im making front and rear trim panels, so all those gaps will be sealed off. not 100% (im going to get it as close to the sides and headliner as physically possible) but im not going to ruin side panels and my headliner (sueding it) by using that foam chit, etc, to seal it 100%, when that VERY SMALL gap isnt going to make a difference for a daily setup...M5 (i dont even know your real name lol) im gonna re measure the inside dimensions, and see what im reallly working with, but before i made that cut on the top to make the box fit in, i was around 11 cubes gross. minus sub/port (still need a port design lol)anyone wanna design me a port?
