Posted October 3, 200718 yr I was wondering if it would be possible to get one of the new BM baskets by itself? also would it acccept a quad coil cone (doesnt look like it so thought id ask) and if the answer to both of those are yes then can i get the specs on it (to see if it will even fit my application
October 3, 200718 yr The basket isn't optimized for a 3" core due to the smaller spider landings, so if you've got a 3" moving assembly I suggest not using it because you're limited to a 7" spider. But if you're going to drop a 2.5" coil in it, it'll work just fine.
